Electric Nightmare - Dodge Diesel - Diesel Truck Resource Forums
Electric Nightmare
Thread Tools Search this Thread
Old 02-03-2017, 11:40 AM   #1
Electrical Nightmare
I have a 99 2500 24valve, with 417xxx kms on the clock. I bought the truck with almost every accessory stolen from the vehicle (lights, pillar gauges, stereo, speakers, trailer brake, etc). I've been working on replacing/repairing everything that was stolen and damaged in the process, but I've run into a few issues that I'm hoping someone can shed some light on:
1. OBD port has no power (Replaced #15 fuse, all other fuses fine)
2. High Beam Indicator stays on with low beams, turns off with high beams (reversed), and stays on when truck is off
3. Left low beam doesn't work, checked bulb and fuses but still not luck
Has anyone had any similar issues, or knows whats going on?
tavishmcguire is offline   Reply With Quote
Old 02-19-2017, 12:56 PM   #2
SIXSLUG's Avatar
A factory service manual may hold some answers.....
SIXSLUG is offline   Reply With Quote
Old 02-19-2017, 04:38 PM   #3
AlpineRAM's Avatar
Since it's kms- I assume Canadian specs.
2.)Take a look at the DTRL module on the driver side fender, below the brake master cylinder. (This module gives you daytime running lights, and controls the high beam indicator on Canadia spec trucks)
3.) Take a look at the ground splice that sits rather close to the driver side headlight, a little below the light on the fender. There are a lot of cables going there and they get ground through the fender sheetmetal, but the post rusts out frequently.
1.) No power or no ground on the connector? How about the data connections? Many scanners offer the option to power them through the cig lighter or sport a battery. It would be interesting to know if it's just the 12V+, ground or everything missing.
And- get a factory service manual! The best return on investment you can imagine!
(Well, I tried to leverage this by buying thousands of them for my truck... but only the first one saved me thousands of $$$, the other ones seem to be defective... I would have wanted to retire on them )
AlpineRAM is offline   Reply With Quote
The Following User Says Thank You to AlpineRAM For This Useful Post:
nothingbutdarts (02-20-2017)
Thread Thread Starter Forum Replies Last Post
2006, 5.9, 24v: Electric Fan clutch to old style, not electric conversion Diesel Girl 3rd Gen Engine and Drivetrain -> 2003-2007 18 10-06-2013 03:03 PM
Has any one done this conversion? non electric mirror to electric mirror cj5er 2nd Gen. Dodge Ram - No Drivetrain 6 12-20-2009 09:19 PM
My 2003 HO Nightmare!! propinc 3rd Generation Ram - Non Drivetrain - All Years 10 08-01-2003 11:11 AM
MOVED: My 2003 HO Nightmare!! Shovelhead 3rd Gen Engine and Drivetrain -> 2003-2007 0 07-30-2003 05:36 AM
Man's worst nightmare NWDave Other 4 03-27-2003 12:10 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Copyright 2011, DieselTruckResource.Com
