Heater Selector Control Knob
Old 09-05-2012, 09:33 PM
MrKen's Avatar
Heater Selector Control ****
Is there a good location to purchase a new heater selector control ****? I have JB Weld the metal clip to the plastic a few times, that is only a temp fix, eventually this breaks too. Figure I would just replace the ****, just don't know if there is a preferred site to purchase from.
Old 09-06-2012, 08:05 AM
patdaly's Avatar
They are cheap from the dealer, or at least used to be. I found a Chrysler that used the same ****, can't remember the exact one, but it was mid to late 90's that had the same **** in the junkyard. It was from the full sized sedan, new yorker perhaps? I think the Intrepid also had the same one.
Old 09-06-2012, 11:34 AM
infidel's Avatar
I replaced mine a couple times before I figured out to slip a tight fitting short piece of copper tubing over the plastic part that always cracked to strengthen it.
Problem solved for now for 14 years.
Old 09-06-2012, 04:02 PM
SIXSLUG's Avatar
I've got three for a 98.5+ if you think it would work......
I can't remember what Dad's 94 ***** look like!!
Old 01-31-2017, 11:34 AM
Ron E's Avatar
That's good information ! Even if it's an old thread
pdhaynie (01-21-2018)
Old 02-01-2017, 01:04 AM
Robert Rausch's Avatar
I used some braided fishing line and some epoxy and wrapped the fishing line around the cracked part and epoxied it. Got 3 years on that fix and all is still well.
Old 02-01-2017, 08:11 AM
VADSLRAM's Avatar
A pick and pull type junk yard. The ***** are on a lot of vehicles.
Old 02-01-2017, 10:26 AM
Busboy's Avatar
It's an old thread but I might point out that at some point, 1995-1998 the heater control was changed from a Bowden cable operated system to an electrical rotary drive system so while the switch panel is the same the actual heater control switch is different.
Old 02-02-2017, 12:40 PM
patdaly's Avatar
97 for sure is cable, so I bet it changed in 98
Busboy (02-02-2017)
Old 02-02-2017, 04:39 PM
Busboy's Avatar
Good to know.
leeboy
02-21-2015 12:15 PM
Gator4
01-30-2012 11:30 PM
atc250r
10-15-2010 10:37 AM
daddy mopar
12-31-2008 06:52 PM
EverydayDiesel
06-22-2007 08:11 AM
Quick Reply: Heater Selector Control Knob
