Broken Kool Vue mirror
Old 05-05-2012, 02:12 PM
dweller's Avatar
I recently folded my driver's side Kool Vue tow mirror in to the door as I was parked on a busy city street. This is the first time that I've ever folded it since I bought them a couple years ago. When I went to fold it back out into the normal position, it did not snap back into its detent. I tried the passenger side mirror and it works fine after folding, but the dirver's side doesn't work. Has anyone else had this happen?
They are assembled with a snap on retainer that is impossible to remove, so I can' figure out how to fix it. Probably too old to warranty...
Old 05-05-2012, 03:03 PM
Beatle's Avatar
Can you just order one from Kool Vue . I have had them for four years now and no problems, Except the plastic does fade a little fast from the Oem Dodge ones. Let's us know if you can just get one.
Old 05-06-2012, 08:14 PM
SIXSLUG's Avatar
Squirt some triflow or similar in there to loosen things up a little before replacing it.
i use Meguiars back to black on my black trims and it keeps them looking pretty good.
Old 05-06-2012, 10:11 PM
dweller's Avatar
No, not a lubrication problem. There is something broken inside the miror base...
Old 06-01-2012, 08:24 AM
305motorsgt's Avatar
I had the same problem when I installed mine. I took the mirror off the truck, then turned it upside down. There is a round cap you need to remove. With a small screwdriver gently tap the round clip around the edge. It worked for me.
Canuckville
19
05-10-2011 08:26 AM
rpdon
0
03-27-2010 02:17 PM
Bubspc
08-14-2008 11:22 PM
Valv
149
06-17-2008 10:22 PM
LockedandLoaded
49
02-02-2008 09:01 AM
Quick Reply: Broken Kool Vue mirror
