Born again - back to diesel
I had an 2004 quad cab 4x4 auto 5.9. I fell asleep in it and wrecked it. I needed a truck fast and didn't want a 6.7. So I bought a 2010 2500 crew hemi 4x4 I just sold because it got terrible gas mile esp if I towed anything.
I am looking for a 1998-2006 ( I like the 1st gen body style better. and the kids are gone) 5.9 24V, 4x4, clubcab. This will be backup vehicle as I don't use my truck fior work any longer, mainly weekends for hunting, camping, trips to Lowes etc.
Is there anything I should look out for in the 1gen 24V
I would like to get a 6sp if I can find one. I noticed some came with 5spd and some with 6spds ...what gives with this?
Thank you
Thank you
Ahh, you will be referring to 2nd gen if you are in the 98-02 range, 3rd gen 03-06, that may help you out some.
there is a wealth of 24valve stuff already written on here, search it and you will save us a lot of typing,
53 block
VP44
Lift Pump
Suspension/steering upgrades
Electronic gremlins
etc
etc.
Also, the Club cab ended in the 99-00 era and is referred to as Quad Cab if you want the suicide opening rear doors, which ended in the 03 year with the Crew Cab style with 4 full doors.
The 6-speeds were an attempt to improve the gear range for towing over the 5 speed. And it did, giving the driver an extra gear between 3 and 4 over the 5 speed, improving pull and scaling down the rpm lag between shifts. It is not an additional gear after 5 as some believe, 5 and 6 are still the same ratio between the two transmissions. The 5 speed is the New Venture 4500 referred to as the NV4500, the 6 speed is the NV5600. The 5600 is a finicky beast and doesn't like to be force shifted but a great trans and almost bulletproof, however the wrong lube and it self destructs, which gets expensive. It has a much larger main shaft than the 4500 and takes a larger clutch. The early ones had some lubrication issues.
A truck with the 6-speed is an HO with 10 more HP than a similar 5 speed equipped truck. There were no HO's with automatic transmissions or 5 speeds.
A lot of the issues have been worked out with mods and aftermarket parts solutions, the problem will be finding a 2nd gen that doesn't have a hundred thou on the odometer, still a solid engine but a tired chassis!!
53 block
VP44
Lift Pump
Electronic gremlins
etc
etc.
guzzirider
06-03-2012 05:11 PM
