Blend door vacuum line routing through firewall?
Defrost only mode this AM, figured it was the vacuum line connection behind the pump. No, all good there. Traced the line up to the firewall. Appears to have failed right where it passes through the firewall, looks like it broke clean off at that point. Can't see a tail sticking out anywhere. Looks like it might be routed where the refrig lines pass through. Hope to get a better look at it this evening when I get home from work.
Thanks,
Neal
Thanks,
Neal
That's very common, if it has sheared off just at the firewall you may be able to poke enough more line through the fire wall so you could hook up to that. If not just poke a new piece through from under the hood an do the splice inside. The vacuum line does go through with the AC refer lines.
Thanks,
Neal
Thanks,
Neal
John,
Your right, sorry about that, been a while since I posted. I thought my sig was set to post. Will check that right away. Laptop STB, working from a tablet, all new to me.
It's a 2001.5.
Odd, my sig info was blank, like I say been a while. Here it is. Sorry about that.
2001.5 2500, QC, LB, 4x4, SLT+, ETH, 3.54 LSD, DiProcal EGT, Boost and Autometer Oil Temp gauges in an Autometer dash pod, SW Electric Fuel Pressure Gauge, Donaldson ECB10506 Air Filter, FASS DRP 02 with KN PreFilter, Dynomax 17223, BU lights that work, EZ, BD IIs, 350 hp 850 lb ft.
Thanks,
Neal
It's a 2001.5.
Thanks,
Neal
Added and enable sig
Sig should appear now. Going to look at this tomorrow. Odd the soft vacuum line runs with the refrig lines. Have to look under the dash and see where the blend door actuator is located. Leaning towards using a short length of hard line to pass through the firewall for the repair.
Thanks,
Neal
Thanks,
Neal
michael_b8
08-31-2007 07:46 PM
johnontheroad
06-13-2007 09:50 AM
carl20320
03-07-2007 05:43 PM
clarson80
02-01-2007 04:27 PM
hipsi
05-01-2005 09:31 AM
