3rd gen 17 dually wheels on 2nd gen dually
3rd gen 17" dually wheels on 1st 2nd gen dually
'05 dually 17" wheels directly fit '96 Dana dually axles
'96 dually 16" wheels will not fit later dually axle, due to rear disk brake caliper interference
- 8 on 6.5" x 4.771" center bore 5.35" offset '94 thru '07
- outside center face to outside rim wall = 1 13/16" offset, same as '96 16" wheel
- fits 9/16"-18 lugs and nuts perfectly - later editions are metric(?)
- center cap latches fit '96 lug nuts tightly for secure hold
Oem 2.35-80x17" Ameri-trac tires are ~2" taller than 2.15-85x16" '96 oem sizing so should reduce effective final drive ratio - also 2" wider, so up goes wind and rolling resistance - hiway tread would help a bunch over the oem road-and-trail tread, also, if you're trying to maintain the excellent mileage of the 1st 2nd gen trucks (12v)
However, the redesigned front caps and covers are way more aerodynamic than the '96 edition, so should help some at any speed
Next: 19.5's..............
__________________
__________________
I did just come in from cleaning, scrubbing and polishing them up for a prospective foto shoot - but, I'll hafta get one of my sons to come over and show me how to use this new-fangled cam-fone, first - I can design\build a monster-motor truck with one-hand tied behind my back, but this new-tech stuff is beyond me - my fingers don't even fit the buttons for dialing - I havta use the one-button call-back feature, which they programmed in so I could call them
Erska
08-07-2007 03:28 PM
Jordan5687
07-05-2007 06:24 PM
CTD NUT
09-12-2005 04:40 PM
CTD NUT
09-08-2005 08:48 PM
