winter
winter
Have a 99 Cummings with 140,000 km on it, was wondering what is the best options for winter....
Dual block heaters if able
Circulating heater
Hi Idle installed
Also I was wondering with that year of truck what kind of oil should I be using during winter... I have 15-40 in it right now
thanks
Circulating heater
Hi Idle installed
thanks
Heck, I don't even bother plugging mine in till it hits single digits.
Make sure your grid heaters work, make sure you have HOT batteries, good connections. Also, somewhere near the low double/high single digits is when I block the radiator mostly off with a piece of cardboard between the intercooler and radiator. Put about an 8" hole in the middle of the cardboard to let some air thru.
If I don't, I never get any heat built.
I run 15-40 year round, but it doesn't get to arctic conditions here.
Funker, where are you located?
Switching from 15w40 to 5w40 rotella synthetic helped my truck a lot... Most of the time they start without problem.. the time it takes for 15w40 to get moving through the system on initial start up is what bothers me.. I run 5w40 all year with temps ranging from -20 in the winter up too 100 degrees in the summer with great results..
Tedonlin150
46
11-21-2011 10:45 AM
wheels
16
11-15-2002 10:46 AM
