Whining noise on acceleration
I have a 2002 Ram 2500 24v Cummins and lately I've been noticing that when I accelerate the motor makes a whining noise coming from the drivers side. I checked all around for boost leaks and couldn't find any. What else could cause this?
A mechanics stethoscope or appropriate piece of wood/dowel will help you track down a noisy accessory.
He also made his own jack stands from a couple of Model-T rear axle housings. Pretty creative he was.
So ive narrowed it down to either a vacuum leak or a boost leak I just cant find either. I had a master dodge tech look at it and he agreed its one of the two
Did y'all check under the driver side battery? There's a 'gizmo' (Name slips my mind) under there that has a vacuum line going to it. Mine snapped off years ago and my ABS and cruise quit working. I Liked the no ABS so I just taped the leak and got used to the lights on the cluster. I don't recall it making a whining sound though.
I would suppose you have a standard transmission, otherwise you can power brake it and listen for the whine/whistle.
That's exactly what mine did and the truck was only maybe 3 years old when it popped driving in from Livingston, Tx to Humble. I do miss the cruise but I don't miss stopping in the middle of the intersection, especially when there's a cop sitting at the light looking at me. He evidently knew exactly what happened because he just grinned at me before I drove on. Now everybody knows I'm panic stopping by the way the rear duals scream as I'm sliding in sideways. LOL
I know this an old forum .... but was wondering if you ever figured out exactly what it was ... think im having the same noise.... 2006 ram 3500 quad cab and chassis dually stock automatic 5.9 cummins
tallboy
12-03-2012 05:57 PM
