What should I see down the breather hole
I took my crankcase breather hose loose at the front of the eng and looked in,what is all the wire down in there by the pump drive?
That is there to catch any oil slung up by the gears and let it to drip back to the crankcase while still allowing vapor and crankcase gases to go out the breather tube.
It looks just like steel wool, but I imagine what is in that breather cap is made from stainless steel. That cap is removable, it just screws into the timing case. That's how you can get to the VP44 gear nut, and also see the timing marks for setting your valve lash.
If you're engine is "making oil" then you need to STOP driving it ASAP, because the fuel is diluting the engine oil which will reduce lubrication to the point of doing harm.
Absolutely, if you are smelling diesel in your oil, that is bad. Like KATOOM mentioned, fuel-oil dilution wrecks the oils ability to lubricate, putting all of your moving parts in the engine at risk. It doesn't take much either, 2% is considered high, which for our engines is only 7 oz of fuel (2% of 11 quarts of oil). I don't recommend driving it either.
If you want to know for sure, take an oil sample and send it to a lab for analysis. Most Caterpillar shops do it. Blackstone Labs is an excellent lab for this. They'll even send you a free sample kit. They charge $28 to run a sample. You'll also be able to see if there's any abnormal wear on the engine as well.
Lordtorquestick
0
08-14-2016 12:07 PM
Mopar1973
07-29-2012 01:47 AM
GO 4LO
11-01-2005 02:59 PM
Dave88LX
09-13-2005 10:45 AM
