Transmission problems
Old 01-18-2014, 10:15 AM
turbottype's Avatar
Yeah I'm still fighting overdrive hunting. But now I got another problem. Traveling at speed 70 mpr my tranny seems to go into 3rd a lot too. I never had this problem. Could it be a sensor back by the rear end or transmission speed sensor.
Old 01-18-2014, 10:47 AM
Tallguy67's Avatar
A couple of of years back I fought tranny issues due to electrical noise for months. Until I solved the electrical issues the tranny was all over the map. Here is the path I would recommend.
Clean all grounds
If doesn't solve the problem, install a transmission noise isolator from Geno's Garage.
If that doesn't solve the problem, this will.
http://www.atsdiesel.com/additionali...02)%20v1.0.pdf
Old 01-20-2014, 07:45 AM
samaf's Avatar
I fought trans problems and found I had a broken wire in the wiring harness that goes to the trans. LOL
Old 01-23-2014, 12:57 PM
turbottype's Avatar
Transmission Problems
After all these years of chasing RF or noise problem from overdrive locking and unlocking. I finally fix the problem. The output sensor was faulty and causing the lock and unlocking issue. My truck run like a new one. The VSS ( vehicle speed sensor) and the OUTPUT sensor need to respond with each other.
Old 07-23-2017, 10:31 AM
Bobby Stout's Avatar
did you ever end up figuring it out?
Old 07-24-2017, 08:50 AM
patdaly's Avatar
Yep, did you read post #4?
kellio
19
03-26-2021 03:12 AM
Dauntless
15
08-30-2016 08:37 PM
DJ Turbo.
10-13-2011 09:11 PM
JARHEAD
06-26-2004 01:44 PM
baldeagle
09-30-2003 08:09 PM
Quick Reply: Transmission problems
