Transmission problem... Help !
Greetings gents, I am having an issue and wanted to get some advise as to what might be the problem. Here are the symptoms:
If the truck sits for a while, maybe a week or so, I will start the truck, let is warm up for a minute or so. I shift into reverse or drive and it will eventually begin to move. the engine speed races, but the truck moves very slowly.
If I drive the truck daily it is seems to be ok...
Any ideas ? Torque converter shot, pump ? Any ideas would be helpful...
Also I recently had a trans tuneup done...
Normal, your check valve in the trans has failed, the TC is draining back.
As soon as you start it, stick it in neutral, wait half a tick, and then try reverse, bet you find it right away.
Most all of them will do it sometime in the life of the trans......
Yup... you guys were correct... I also found my front tranny lines were a bit weepy and the rear tranny seal is oozing.. will get these fixed next week... Will a transmission shop be able to fix the check ball issue ? I read somewhere that there is a kit that can be installed that fixes this too...
bigfish5
09-12-2008 11:14 PM
