Rear brake pad replacement, smoked new pads
I just replaced my rear brake pads and took her out for a short test drive. As soon as I pulled out of the drive way it felt like I was dragging an anchor.
I pulled over and saw lots of smoke coming from the left rear inner pad.
I crawled under and pried the caliper over to release the brake a bit, and it seemed ok driving back to the house.
Is there a trick to replacing rear disc brake pads?
Did I miss something or am I looking at replacing both calipers?
I figured the boots kept the cylinders clean from outside dirt.
my guess is there must have been pitting or corrosion on the cylinders.
So there is no easy fix besides replacement?
Will the pads be salvageable?
Hard to say without seeing them . Are the rotors blue if they are they could be done it all depends how they look . You might be able to turn the rotors but what happens they warp easy after been heated that bad????
When I did mine I opted for new calipers for just this reason. The rears don't really do much unless you are loaded down. The pistons can corrode from any moisture inside and hang up.
Did you grease the slider surfaces? That will certainly help them release...
I didn't drive it too far, I pulled over and with my trusty screw driver, I was able to pry back the caliper and drove it home so I saved the pads and rotors.
I went to Advanced Auto Parts for a pair of rebuilt calipers and enough DOT 3 to flush the system. BTW exchange calipers with hardware kits are $55 with a life time guarantee. When I do the rears again, I'll automatically swap them out and make use of my guarantee!
Next weekend I'll replace the front pads, hopefully I wont have to do calipers too.
Be sure to clean up the metal slides and pins, then coat them with synthetic brake hardware grease. It is available in small tubs at parts stores.
The use of petroleum based greases or lubricants on the slides and pins with rubber covers can compromise the integrity of the rubber material, therefore causing it to swell and eventual failure of the rubber. Synthetic brake grease is also tolerant of the temperatures created by braking.
Wen in dought change them out. Spend the extra when you do the front and by the way 10 year old vehicle you need to do both brake hoses!!! My front brakes are coming due and thats my next step.
Not replacing hoses also increases the chances of a line blowing out. Brake hoses and lines should be visually inspected for signs of damage and corrosion at regular intervals ... Perhaps during each tire rotation procedure. Leaving brake lines on too long also increases the likelihood of a collapsed rubber line. When a line collapses, it can cause several symptoms. The most common symptom is a pulling condition. It is relatively difficult to diagnose a collapsed rubber line because you cannot physically see the inside of the line. The rule of thumb is usually if the vehicle pulls to one side while braking and the caliper shows no damage, then replacement of the brake hose is required. I hope this helps.
madhat
45
09-19-2009 07:23 AM
Hunter11
03-17-2007 01:10 PM
2-Stroke
03-12-2007 09:38 AM
