Please help, running out of time. power to ground problem motor and frame are energiz
Old 09-22-2014, 02:42 PM
dustinbabin's Avatar
99 Dodge Ram 3500 SLT 2WD 5 SPD.
Engine wire harness was all rigged up so I replaced everything coming out of the PDC connector including the two firewall disconnects, everything going to engine, ecm, pcu with a harness from a base model 99 ram 2500 diesel 2wd auto. ECM fuse blows immediately, abs module won't turn off, I'm working on it now. Have grid heater system off, pcu disconnected... Still have short. Disconnected grey connectors near aux battery coming off negative terminal short stops. Plugged back in and disconnected ecm and short goes away.
Also is there any difference from an early 99 to a late 99
dustinbabin
09-23-2014 11:31 AM
Mikestowing
18
03-28-2010 08:07 PM
gts95
08-27-2007 10:13 AM
95black2615
12-20-2006 06:37 PM
ptgarcia
09-12-2006 06:04 PM
Quick Reply: Please help, running out of time. power to ground problem motor and frame are energiz
