NV5600 Cracked
Old 07-02-2013, 01:05 PM
shawn085's Avatar
Angry NV5600 Cracked
I just pulled my transmission to replace the clutch. This is what I found once it was out. I've never heard of this but I'm sure I'm not the only one with this. Any suggestions on how this happened? Truck is a DD and I don't tow much. If I do its not more than 10,000lbs. From what I've read its a total transmission disassembly to fix. Any hints would be great.
Old 07-02-2013, 08:57 PM
SIXSLUG's Avatar
That is the bellhousing, not the trans...
Haven't seen or read about this before. Belhousing shouldn't be too steep to replace.
Old 07-02-2013, 10:16 PM
jhenson's Avatar
^^^^^^ditto.......bellhousing is easy to replace.....unbolt old....bolt on new.
Old 07-02-2013, 11:46 PM
shawn085's Avatar
Nv5600
The bell housing is an integral part of the transmission on the 5600. If you build up one of these. Step one is put bell housing on the bench as the base of transmission. Then you start putting all the guts together and fit the case over it. I'm looking for the parts, and might try the replacement myself. But if anyone has any hints, tricks or wise words please let me know.
Old 07-03-2013, 04:06 AM
sean.marble's Avatar
just throwing it out there,you could replace the houseing,or on a cheaper note you could get some cast welding work and try and fix it
Old 07-03-2013, 08:12 AM
SIXSLUG's Avatar
I'll look in my FSM, but am pretty sure its not that big of a deal....
It almost looks like the trans may have been left unsupported previously. I notice it is marked "OK" like maybe it was a junkyard/replacement trans.
As you are now aware, the 5600 is no lightweight.....
Good luck!
Old 07-03-2013, 07:19 PM
SIXSLUG's Avatar
The Bellhousing is an integral part of the 5600! My bad.
I wouldn't think the bellhousing would be too hard to find, you may have to buy an entire lunched 5600...I hope not.
Old 07-05-2013, 12:01 PM
Redlinear's Avatar
I'd have it welded before I did the job of changing one. It's somewhat of an ordeal to replace.
Old 07-19-2013, 05:06 PM
dieseldemon's Avatar
My vote would be WELD IT not a big problem
klx650a2
04-20-2009 05:25 PM
autotecsvc
16
03-07-2006 07:17 PM
WVPANHANDLER
02-01-2003 08:23 PM
Buzz
12-14-2002 07:29 PM
Dodgezilla
11-24-2002 07:31 AM
Quick Reply: NV5600 Cracked
