no power at first start up
Old 07-26-2013, 08:13 AM
ARK2001's Avatar
I have a 2001 2500. When I fisrt statup in the mornings, I have no power. I can push the throttle all the way to the floor no changes. After about a quarter mile down the road all power comes back. I put a pressure gauge past the fuel filter. at idle 14/15 psi, wot 9/10. Does any one have any suggestiouns.
Old 07-28-2013, 09:24 AM
U&I
U&I's Avatar
You do allow the truck adequate time to warm up to operating temp before you head out down the road right ?
Old 07-28-2013, 09:27 AM
ARK2001's Avatar
yes, I will let run for about 15-20 min before leaving
Old 07-28-2013, 10:39 AM
Mountaineer's Avatar
No changes in RPM or no change in speed ?
Old 07-28-2013, 12:37 PM
ARK2001's Avatar
The RPM's and speed come up slowly, no matter how much throttle I give
Old 07-30-2013, 12:13 PM
67HotRod's Avatar
Almost sounds like brakes dragging.
Old 07-30-2013, 01:41 PM
nkennedy's Avatar
If it won't rev at all it could be the APPs/throttle pos. sensor.
Old 07-30-2013, 01:48 PM
ARK2001's Avatar
Is the APP/throttle pos. sensor hard to change or is there a way to reset?
Old 07-30-2013, 02:26 PM
Tallguy67's Avatar
There is an apps reset procedure. I will see if I can find it using search. If you are watching this, maybe ry the same. If the apps is on its way out, be sure to replace it with a Timbo APPS. Timbo is a guy who is on this board and who makes an upgraded app that is cheaper and better than the stockers and it is super easy to install and calibrate.
Old 07-30-2013, 02:42 PM
Tallguy67's Avatar
The thread below is a thread about replacing an apps. Timbo1 is the third person to post in the threda. PM him and he will explain how to order an apps from him. I am still searching for the apps reset procedure.
Old 03-18-2015, 11:10 AM
ARK2001's Avatar
if I where to run straight exhaust.do I need have my truck reprogrammed?
Old 03-18-2015, 08:38 PM
DIESELWRKS's Avatar
on all years of Dodge cummins prior to 2007.5 pre egr/dpf (pre emission).
they can all be ran with a straight pipe without causing a issue. no tuner needed.
cons.
louder than one thinks.
if you require a smog check of anytype this may or could make you not pass with missing muffler and or muffler and cat if equipped.
pros'
sounds great. some cooling egt's , better spool up with turbo.
Old 03-19-2015, 02:02 PM
ARK2001's Avatar
Thanks for info. Thank you for serving this great country.
Sarajaye
11-21-2014 06:14 PM
CoolumConst
10-11-2008 10:00 PM
5.9Excursion
Cummins Conversions
03-20-2008 04:47 PM
BulletMan
10-31-2003 10:02 AM
Quick Reply: no power at first start up
