no power at first start up
I have a 2001 2500. When I fisrt statup in the mornings, I have no power. I can push the throttle all the way to the floor no changes. After about a quarter mile down the road all power comes back. I put a pressure gauge past the fuel filter. at idle 14/15 psi, wot 9/10. Does any one have any suggestiouns.
There is an apps reset procedure. I will see if I can find it using search. If you are watching this, maybe ry the same. If the apps is on its way out, be sure to replace it with a Timbo APPS. Timbo is a guy who is on this board and who makes an upgraded app that is cheaper and better than the stockers and it is super easy to install and calibrate.
The thread below is a thread about replacing an apps. Timbo1 is the third person to post in the threda. PM him and he will explain how to order an apps from him. I am still searching for the apps reset procedure.
on all years of Dodge cummins prior to 2007.5 pre egr/dpf (pre emission).
they can all be ran with a straight pipe without causing a issue. no tuner needed.
cons.
louder than one thinks.
if you require a smog check of anytype this may or could make you not pass with missing muffler and or muffler and cat if equipped.
pros'
sounds great. some cooling egt's , better spool up with turbo.
cons.
pros'
Sarajaye
11-21-2014 06:14 PM
CoolumConst
10-11-2008 10:00 PM
5.9Excursion
Cummins Conversions
03-20-2008 04:47 PM
BulletMan
10-31-2003 10:02 AM
