Lost power to mirror, radio and interior lights
Old 11-06-2006, 10:55 AM
themacfive's Avatar
2000 Dodge Ram 2500 as my husband was adjusting his driver's side mirror, he suddenly lost power to both mirrors, the radio and the interior lights. He checked the fuses and they seemed fine....any ideas? Trying not to overpay the dealer for the problem when it seems like its something simply.
Old 11-06-2006, 12:46 PM
XLR8R's Avatar
Check the correct fuse(s) in the underhood PDC and the driver's side dash fusebox; all of the switches and relays are labeled and replace with a known good fuse, unless he has a meter to check them with (the open is not always visible).
Old 11-06-2006, 12:53 PM
themacfive's Avatar
We did that! We are sooooo perplexed!
Old 11-06-2006, 03:26 PM
XLR8R's Avatar
Start tracing the wiring for voltage; begin at the fuse out terminal for the circuit and confirm that voltage is present at the wire's next connection, etc.
It IS something simple, since it affected all of those circuits at once...
Old 11-06-2006, 03:40 PM
bnold's Avatar
I believe the fuse for that is the one with a black cover on it (interior fuse panel)... Took me a while to find it when I shorted my interior light. The black cover made me think the truck would self destruct if I pulled it, but it was the culprit.
Old 11-06-2006, 03:58 PM
mopargw's Avatar
check the fuseable links from the battery. feel them with your fingers and if any feel spongy cut it out and either replace with another one or an in line fuse of the correct amperage and gauge of wire. I did that with a 1984 W250 and lost all of the interior lights and headlights.
Old 11-06-2006, 07:15 PM
torq's Avatar
i had this same problem once when i first purchased my truck thought i had checked all the fuses also but there is one in the cab that is not marked as to be obvious of what it fuses if i remember correctly. i would recheck all of them if i were you.
Old 11-07-2006, 07:24 PM
themacfive's Avatar
Thank you thank you!!! It was a fuse in the black box....we skipped right over it. Thanks a million!
Old 11-07-2006, 08:38 PM
XLR8R's Avatar
That's what I thought...
Old 08-06-2013, 10:00 PM
tkohl's Avatar
Which fuse was it I'm having the same problem
Old 08-08-2013, 11:48 PM
mrclean's Avatar
The IOD fuse......should be #12 in the fuse panel on the side of the dash.
Old 06-23-2019, 12:35 PM
MattD243's Avatar
Fuse
I'm having the same problem, but I checked all the fuses and I've got power to them, except for the illum. Fuse(5a) but the fuse is not blown, please help!
Old 06-23-2019, 12:54 PM
AlpineRAM's Avatar
Are you sure that your IOD fuse (behind the black cover ) is OK and gets power?
The illum fuse gets it's power from the IOD fuse.
GEC
03-20-2014 09:44 PM
stratos201proxl
01-16-2014 11:04 AM
ehammett
13
12-30-2008 05:20 PM
Nor_Cal_Angler
16
11-11-2008 10:24 AM
Quick Reply: Lost power to mirror, radio and interior lights
