Leaking Transmission Lines
I've been slowly Going over my latest edition Trying to get it all buttoned up. I bought a low profile drip pan to put underneath it To locate any of the weeks I have. It turns out that my transmission lines Where they attach to the steel lines coming off of the cooler Are leaking around the quick connects. I'm wondering if I should just order replacement lines Or if there is a better product out there to replace those connectors. Its leaking pretty bad.
Are you sure its the trans lines
The crankcase breather is directly above them and will leak al over them and the steering box
Put a pill bottle over the end of the crankcase breather and cabletie it in place , degreace everything and check it again
91rangerturbo
05-08-2008 08:05 AM
91rangerturbo
03-06-2008 09:40 PM
