HELP! Auto Stuck in high gear and wont shift. lots of smoke
Truck info - I have i 2001 cummins 24v AUTOMATIC, 140k miles, new engine, Fass, DDP 50s.
Truck Problem - I was going bass fishing yesterday and it drove just fine to the pond. but when i left it had no power and was dumping smoke. it feels like its stuck in 3rd... or a higher gear then first. if i go from a stop it takes forever to increase RPM and blows tons of smoke like there is alot of load. HOWEVER if i manually put it in first or second (auto trans) it relives the problem.
Scenario - Im at a stoplight and i take off with no power dumping tons of smoke... Like trying to launch a manual in 3rd gear. So to make it home without painting the road black i had to manually put the truck in 1st then shift into drive when im at the top of first... and evin then if i try to get on the freeway it will not go into the last gear. it is stuck in one gear unless i manually shift it to first or second.
Diagnosis so far - i figured someone would have had the same problem as im having on here so i have been searching peoples threads and all i can find is people that are stuck in first gear and saying its a gear sylinoid or they are in Limp mode and saying its the TPS. SO i have decided to post my own thread and see if anybody could help me out with my specific issue. If you need to know more info just ask in replys. THANKS!!!!!
Broken - There are some people who know a lot about trannies on here so I am sure someone will chime in soon. One of the first things anyone is going to ask is whether or not you have put a code reader on your truck to check for diagnostic trouble codes. If you don't have a code reader, most auto parts stores have them these days and they will let you borrow their unit and check for codes in their parking lot.
thanks i will go do that
*edit* Okay i got the codes
P-1682 (low charge output?)
p-0743 (this looks promising)
p-0123 (TPS Voltage too high?)
p-0753
P-1765
p-1694
p-1693
I know its throwing all kinds of tranny and tps related codes so my truck must be Edit done. im ******
p-0753
P-1765
p-1694
p-1693
rynojr4644
14
05-18-2009 07:23 AM
