front end problem
Old 07-14-2013, 03:19 PM
td3620's Avatar
Question front end problem
i replaced all my tire rod ends.one was wore out,so i replace everyone.but it still road walks bad side to side.do i need to replace tracking bar or maybe control arm? Im just tired of it.Need help to fix my no problem.Thank you
Old 07-14-2013, 03:43 PM
RottnRam's Avatar
I just replaced everything on my 02 and after counting the threads and measuring twice I still had to get it aligned. I also have a DSS mounted so it helps. If you have the money replace everything and have it alignment done. Rule out all possibilities.
Old 07-14-2013, 08:45 PM
gorms's Avatar
Any loose joints need to be replaced before alignment. Check all closely while someone pulls the steering wheel back and forth 1/4 turn, easiest way to find out if the track bar is shot. You may also see the sector shaft on steering box (pitman arm) moving around a bit. DSS or similar steering brace stops that as said above.
Then have it toed in 1/8" inch.
Old 07-15-2013, 09:36 PM
SIXSLUG's Avatar
In my readings and experience, trac bar tends to go first, which results in ball joints and tie rod ends slacking out.
Steering box can also be affected, but usually the parts closest to the wheels go bad first.
Check end bushing at axle as mentioned above regarding trac bar...
Old 07-15-2013, 11:49 PM
td3620's Avatar
ball joints good and tie rod ends are brand new .trac bar is still factory.geuss ill replace that and see
Old 07-16-2013, 03:28 PM
rotohead's Avatar
I would suggest installing a 3rd gen track bar instead of any OEM bar. Get the adapter and be done with it once and for all. DSS stabilizer is a great upgrade too.
Old 07-17-2013, 10:20 PM
td3620's Avatar
how much would that cost me?
Old 07-18-2013, 10:23 AM
dubc2323's Avatar
150-200 for the steering box brace depending on brand and roughly 500 for the track bar conversion kit w/ adjustable track bar
1999blackcloud
01-26-2010 08:52 AM
piperca
15
05-24-2005 10:23 PM
Gordonville
04-18-2005 09:45 AM
royta
07-13-2004 06:54 PM
97RAM
07-01-2004 12:08 PM
Quick Reply: front end problem
