Driver side axel u joint
Old 07-19-2013, 10:47 PM
chevycantkeepup's Avatar
I have a 99 dodge 2500 cummins and the driver side u joint is shot i was wondering if any of you guys performed this procedure. i was told ithat need to take the pinion out to take the axel out and what is the best way to get the caps out
Old 07-20-2013, 01:02 AM
Cummins Guru
BigIron70's Avatar
Location: Sunny Southern California Land of Fruits and Nuts
No You don't, just caliper, rotor and hub bearing. Axle will pull out easy once that is done. Be careful if you have ABS brakes that you remove sensor before pulling axle shaft out.
O.fO.shO
01-07-2012 02:26 PM
surfram
08-18-2009 03:09 AM
dr.caterpillar
06-07-2009 06:07 PM
Geets
14
10-12-2005 08:01 PM
JImbo1
04-09-2003 07:46 AM
Quick Reply: Driver side axel u joint
