oil
Old 08-11-2005, 07:21 PM
jim54's Avatar
Question oil
i just recently purchased a 2001 dodge cummins,24 valve turbo with 126,000 miles. it is so far everything i hoped for. would synthethic or rotella t, be better to use in it? i would appreciate any thoughts on this this,as this is my first diesel, and i am learning as i go.
Old 08-11-2005, 07:41 PM
P.J
P.J's Avatar
Much debated topic, I like Rotella T myself. Others will say syn, but I just can't see the extra cost. I would assume there is a formula that shows the extended change interval v.s cost? (somewhere).
There has even been a few Polls on the topic.
Make sure you brush up on the fuel filter change and other common tips.
http://www.dodgeram.org/tech/dsl/fil...uel_filter.htm
Oh, and WELCOME!
Old 08-11-2005, 08:03 PM
jim54's Avatar
oil
thanks much ,,pj from what little i have learned,,very little. i'll stick with the rotella t notion then.
Old 08-11-2005, 08:04 PM
Cyborrg's Avatar
Oil and filters are the simplest and most debated topics.
I use Royal Purple and fleetguard. 10k intervals. The filters are relatively cheap and I'm toying with the idea of changeing filters at 5k.
More important is to just change the oil as recommended, and use a filter off the approved list.
Also, I heard from a reliable source that Ford owns Amsoil.......
Old 08-11-2005, 09:00 PM
Geico266's Avatar
Welcome and congrats on the truck. You are just getting it broke in! Only Rotella for me.
Please fill in your signature so we know what truck you have, miles, extras, ect. any unmarried sisters, rich old uncles stuff like that.
Old 08-11-2005, 09:25 PM
Registered
blackdiesel's Avatar
i use rotella t syn. they say that mobil and amsoil syns are the 'best'. most guys are going to run regular rotella t. ex. truckers, ctd drivers, etc. etc. Rotella T is a really good oil, ya just hvae to change it more often.
Old 08-11-2005, 09:26 PM
Registered
Old 08-11-2005, 10:08 PM
BEHRMAN's Avatar
Use Rotella T Synthetic.
Old 08-12-2005, 06:24 AM
jim54's Avatar
thanks all, really apprreciate all the input.
Old 08-12-2005, 08:27 AM
Mopar1973man's Avatar
I've been using Phillips 66 and Exxon Dino oil from day one without any ill effects on the truck.
Old 08-12-2005, 08:40 AM
Geico266's Avatar
How are you doing on the filters? fuel, air, oil? Good idea to check boost boots, connections, balljoints, fuel pressure. You need to keep your baby running happy.
A fuel pressure guage is an absolute must do this weekend.
Old 08-12-2005, 11:57 AM
CSAGrey1's Avatar
DELLO
I change my fuel filter every 3rd oil change.
Old 08-12-2005, 01:06 PM
RowJ's Avatar
Re: oil
Welcome to DTR.
You ask a question that has produced wars in the past! (no way you could know).
Old adage = "Never insult a mans wife...or his choice of engine oil"!
Simple answer...use your Rotella, and change @ 5,000 miles. Go with synthetics and change @ 10,000 miles. Your choice.
What you won't get much arguement on is...Use a Fleetguard Filter!
RJ
Old 08-12-2005, 01:10 PM
RowJ's Avatar
Re: I bought a truck with about 20k on it
Originally posted by jumpinj
....didn't see a change interval for the fuel filter. Should I do this just as a precaution.
I would change it...so I knew it had been done.
After that...I would recommend @ 15,000 miles.
RJ
Quick Reply: oil
