53 Block Cracked - ISB215 to ISB190 Swap Questions
Hello all, my 53 block has cracked and neither Cummins nor Dodge will do anything about it so I am looking to swap in a "new" motor. I have located a good running 1999 5.9L engine in a Ford Medium Duty F800 local to me. My "old" motor is an ISB 215 and the "new" motor is an ISB 190. Fuel rates are different, 80 versus 87 and the timing noted on the tag of my "old" motor says 100 MM, whereas the "new" motor's tag says timing ELECTRONIC. Does anyone know if these motors are interchangeable and the ISB 190 motor will run correctly with my "old" ISB 215 brain? Thank you and good day.
klx650a2
04-20-2009 05:25 PM
