100hp+ engine, trans/clutch doesn't like it
did you install the apps sensor. was it a oem factory replacement for $$ alot of money that one. or was it Timbo's APPS sensor that was like 160$. as I ask because I believe the process to calibrate for both of them are diff. I'm confused on the let out clutch part and vehicle "REVS UP" . how is your idle after replacing these parts. do you feel the throttle response is slower or faster since the apps was replaced. All of my clutches that went bad. Stock, SB-Con FE, they both made my truck blow alot of black smoke when getting on throttle , Rpm's shot up and speedo went down. it was a instant feeling and instantly showed on gauges. it didn't hesitate. right around the 1900rpms range using 3rd, or 4th.
Shes a beaut!
somarillw, where are you from?
I would call Peter at South Bend, then give Lary ( TOP ) on here a call, he has treated me very well.........
https://www.dieseltruckresource.com/...er.php?u=18533
Shes a beaut!
Double disc simply gives you 2 discs so they can be slipped more before destruction. It is a way to get more surface area to grab.
Pullers sometimes use 3 and 4 disc slipper clutches, but those aren't what you would want for the street ( and they are bloody expensive ).
Unless you are going to get stupid, a good South Bend will suit you just fine, but rather than listen to any of us, give the man who builds them ( Peter ) a call, be very honest about what you have, what you do, and what you intend to do in the future and ask for his advice.
I have a DD3250 waiting to go in when I kill mine, I will never need that much clutch, but Lary gave me such a screaming deal, I couldn't wait till I needed one.
That, and I only ever want to have to haul that heavy thing out once........
Derek Crowl
08-20-2013 10:43 PM
hot_runner58
12-15-2011 09:29 PM
turbos10
03-27-2011 11:17 PM
jasonjones
13
05-01-2005 09:30 AM
Dave04600
06-09-2004 04:55 PM
