02 Ram 2500 rear disc brakes drag.
My 2002 Ram 2500 ( 88,000 ) miles, rear brakes drag. I have had this problem before, replaced calipers on both side, flushed brake fluid, put on new pads. And now its doing it again. Im the original owner, never baja the truck, the thing has been taken care of very well. Anyone else ever have this problem?
Thanks Ray
Thanks Ray
Do what he said^^. Mine did this also after a winter trip to MT and back. I try to do this every time I rotate the tires.
You may have a caliper hanging up if the above doesn't do the trick...
Where in WA?
Where in WA?
From the ones I've seen, the problem is usually rust in the caliper bore around the outside of the slide bushings. When it gets hot, the rust expands much more than the metal, effectively pinching the slides tight. You need to remove the rubber slide bushings and hone out all the rust in there, then replace the bushings.
Truck For Sale 2001 2500 4x4 cummins 4 wheel disc brakes
horselady
2nd Gen All Products
02-28-2016 05:21 PM
1992 Renegade
10-11-2014 03:29 PM
2500CTD
10-19-2010 07:10 PM
mr4732
10-21-2007 05:12 AM
