02 blowing white smoke
Old 09-03-2015, 07:44 PM
1stgenatheart's Avatar
Hey Guys!, Its been a while but I am looking for some help with an issue with my Dads 02 VP truck. Here is the deal. When first started it starts and idles well until it gets to about 1500 rpm then it starts blowing white smoke and missing. If we shut it off and then restart it runs fine. We just replaced the lift pump and are running about 12psi under load. He has had a fuel pressure gauge on it for a while now to moniter the whole lift pump situation. The truck only has 40,000 miles with a six speed and is BONE stock. Any help would be appreciated. PS we aren't getting any codes ither
Old 09-04-2015, 11:48 AM
SIXSLUG's Avatar
Could be a blown intake boot, antifreeze in cylinders from blown head gasket, or a failing vp....first two don't throw codes.
Old 09-05-2015, 09:40 PM
KATOOM's Avatar
Check both the coolant and engine oil for milky appearances or odd levels. Check for any codes in the OBDII system.
Old 09-10-2015, 12:41 PM
jrs_dodge_diesel's Avatar
I would not rule out the possibility of an injector going bad either. Unburned fuel will show as white smoke too.
nbaggett89
11-05-2008 06:42 PM
crash4wd
12-17-2007 08:48 PM
joe_yba
06-10-2007 05:42 PM
Ian
04-18-2006 10:08 AM
Palmetto_kid
01-20-2003 06:01 PM
Quick Reply: 02 blowing white smoke
