wiring for trailer lights
hi,
what would be the proper way to wire truck for trailer light plug? i was unable to find a wiring kit at any of the local part stores, only had the plugs and adapters so i was thinking find a wiring diagram and just tap into the existing taillight wires? any recommendations or wiring diagrams
thanks in advance
thanks in advance
not sure exactly what standard is but at work all of our trailer plugs are J560 7pin plugs and is wire
looking at the back of plug
Top center is ground (white)
Top right is Tail (brown)
Top Left is ICC markers (Black) We jumper the ICC Markers and the Tails together because theres no need for us to run Markers and Tails seperate
bottom left, i believe is Left turn (yellow)
Bottom Right is Right turn (green)
Could have these two mixed around.
Bottom Center is Trailer brakes (red)
And center center is Blue which we use for AUX 12 for charging break away battery.
Trailer brakes i've seen wired as a blue wire and 12v aux as red,
but for the most part
Left turn Yellow
Right Turn Greet
Markers Brown
Ground White
Brakes red or blue
Or as my cousin (who took diesel tech) told me Oh color doesn't matter it will still work the same lol....
Left turn Yellow
Right Turn Greet
Markers Brown
Ground White
Brakes red or blue
I would definitely add a relay for the tail/marker light circuit so you avoid drawing extra current through the truck's headlight switch. Replaced dozens of burnt up switches and connectors on 1st gen trucks from that circuit being overloaded.
If you have a big trailer with lots of lights I'd run new circuits with relays. If not to many lights or they are all led then you could just tap into your dodge wiring. The thing with that is if something shorts on the trailer you loose truck lights too. It's up to you. I will dig up some diagrams later on and post them up for you if need be.
I second that. Also, replacing all trailer lights with LED's takes a big load off the headlight switch.
Received 1,637 Likes
Great advice here, guys.
I was going to purchase the tail light converter which is a plug and play system
http://www.etrailer.com/Custom-Fit-V...dy/118317.html
But, in order to save $$, I just soldered in some new connections to the new trailer connector I put on my truck listed here.
http://www.etrailer.com/Accessories-...ler/ETBC7.html
It's an incredible value, as you get your electrical connectors, wire, plug and circuit breakers all in one kit. You really don't need anything else, other than basic hand tools and a few more zip ties than they provide.
This kit allows you to run electric brakes so you don't have a trailer pushing you into the car in front of you.
If you buy the harness plug and play, it plugs directly into the connector for the trailer plug included in the kit, and there's no splicing at all.
This is going into a waterproof PVC wiring box mounted in the frame just behind the cab.
That prevents both accidental draining of the engine start battery, and back feed of high current from the trailer during engine starting.
I use the same circuit to hook up snowplow hydraulic pump batteries.
I just noticed the battery circuit doesn't go through the master fuse. The original design was to put the panel near the battery. There's more room, and wiring, especially brake controller, will be shorter by locating the panel underneath. I'll change the drawing.
hope it helps
John
Here's the factory schematic for a 1993. Use this with what that ^dude^ gave you and you should have a bullet proof trailer wiring circuit! Hope that and this helps. Don't forget black tape and butt connectors aren't very good for wiring. Solder and heat shink are the best things you can use. NO SCOTCH LOCKS!!!
Good luck.
Good luck.
