Wiring floor mounted high beam switch for o/d?
I picked up a floor mounted high beam switch that I'd like to use for a o/d switch. I have a 47rh and I'm tired of toggle switches. My only concern is its a 3 wire switch. Only 2 wires will be in use. I know people talk about using these for o/d switches hopefully someone can help me out
Do you have a VOM? If not, easy enough to wire up a cheap light bulb circuit to test.
Yes I do. The switch has to be grounded to made o/d work. So if I put the signal wire from the trans to the center wire of the switch and then ground one of the other wires, should work?
IPDiesel
12-16-2010 04:25 PM
