Warn Hubs
Old 09-29-2016, 08:09 PM
Received 1,637 Likes on 1,112 Posts
Warn Hubs
For you 4x4'rs
when you lock your hubs is there any play between the hub and the axle that you notice ? Today, I tested my hubs with the wheels in the air, and I noticed a decent amount of play in the hub as I rotated the wheel forwards and reverse.
Time for new hubs ?
Old 09-29-2016, 08:32 PM
mknittle's Avatar
Originally Posted by NJTman
For you 4x4'rs
Time for new hubs ?
It seems that there are 6 splines in those hubs one machined one broached and four cast so there can be quite a bit of slack in them.
NJTman (09-30-2016)
Old 09-30-2016, 11:35 AM
maybe368's Avatar
For you 4x4'rs
Time for new hubs ?
Mine has some play in there. I don't think that it is supposed to be a real tight coupling and that the play is by design...Mark
The following 2 users liked this post by maybe368:
mknittle (09-30-2016), NJTman (09-30-2016)
Old 10-12-2016, 06:38 PM
DoodleBee's Avatar
I can check mine this weekend - I rebuilt/packed everything, bearing/races/seals. I don't remember any play after loading and setting the nuts. This was a couple months back.
cheers
Doug
Old 10-12-2016, 07:16 PM
Received 1,331 Likes on 862 Posts
Mine seemed pretty tight as well. Not much play.
Old 10-13-2016, 07:07 AM
After locking the hub, when it's turned from one direction to another, there is at least 2 or 3 degrees of play before the shaft moves along with the rotor.
I guess it's time to buy new ones...
Old 10-14-2016, 11:19 PM
Ol-dodge1992's Avatar
Anyone know if the "turn ****" that locks/unlocks the hub is available to purchase without the entire hub... mine is broken on passenger side and I can only grip it with pliers... NAPA wants $197 for entire hub set ???!!
Is there sticky thread for replacing them and how do you determine its time to replace??
I have a growling from time to time on left front when locked in ... not sure if it growls when unlocked just can't remember right now.
Old 10-15-2016, 10:43 AM
Rick 12v CTD's Avatar
The growling may be the hub, but it also may be the axle u-joint
Jack the tire up, lock the hub and spin the tire and see if you can hear anything. Maye you'll be able to pinpoint it
Old 10-15-2016, 11:40 AM
Thanks rick ... I'll give it a try and see if I can diagnose a little further
ChrisJohnson
13
07-11-2012 07:14 AM
91oldranchtruck
01-31-2011 09:45 AM
BHD
07-16-2007 10:48 PM
phox_mulder
05-29-2004 10:19 AM
Quick Reply: Warn Hubs
