Vents covered on doors??
Old 09-27-2016, 07:42 PM
rlyons's Avatar
The vent slots on the front edge of my doors are covered with some sort of self sticking black material. Is this supposed to be there or is it something the po did to control noise or diesel smell or something?
Old 09-27-2016, 08:15 PM
samiam4's Avatar
No its a owner improvement. I'm sure it reduses noise.
M
Old 09-27-2016, 10:22 PM
Philip's Avatar
Actually that was factory. I have looked at many doors with that on it. If you peal it off you won't find material that good to replace it with.
Its to cut down on window blowing into the door under pressure.
Old 09-28-2016, 10:10 PM
rlyons's Avatar
Ok,I see. One side of mine has the thick material on it but is peeling off, the driver's side has been replaced with duct tape. I guess it is time to look for something to replace it with. Thanks.
Old 09-29-2016, 05:49 PM
j_martin's Avatar
You could use
1. Gorilla tape
2. The heavy seam sealing tape that is used to repair RV roofs, or even holes in the siding.
3. The "100 mph" tape that is used to repair RV belly boards. (very thin)
Old 09-29-2016, 06:45 PM
jerseybud's Avatar
I'm not sure if it just came on 93s or if was just diesels....
Definitely stock
I replaced it with butyl weatherproofing from a door off a grand caravan, cut it to fit and then 3m 8090 adhesive. Adhesive wasn't strong enough so I just used dynamat.
Old 09-29-2016, 07:07 PM
edwinsmith's Avatar
Received 1,038 Likes on 763 Posts
What about the aluminum duct tape? Not regular duct tape but the kind that is an actual strip of thin aluminum metal with adhesive.
Old 09-29-2016, 10:24 PM
Philip's Avatar
I just used some left over dynamat on my door vents. When I was sound proofing the new cab.
Troppy41
07-26-2016 06:27 AM
marder
12-06-2015 12:10 PM
xp8103
13
04-06-2011 12:55 PM
hognutz
14
09-15-2009 06:53 PM
rlyons
11-07-2006 06:50 PM
Quick Reply: Vents covered on doors??
