Tell me a bout suspension droop? D250
Old 01-11-2017, 02:29 PM
samiam4's Avatar
I'm asking as it appears I have a bit on the LHS. The hood is maybe 3/8 of an inch showing on that corner maybe a bit less. But I'm looking in the TSBs and there is a LHS spring space to compensate for 1 inch of droop.
I have new Moog springs and it made no difference. I always assumed that maybe I needed to replace the radiator support bushings.
Suggestions?
M
Old 01-11-2017, 05:43 PM
u2slow's Avatar
Body mounts and rad support mounts are a good place to start.
The left side of these trucks is heavier.... battery, steering, fuel tank, driver. It all adds up.
Old 01-11-2017, 05:46 PM
kensmachine's Avatar
Radiator bushings cab mount bushing rear springs take your pick. I put new cab mounts on my truck you can only get the poly mounts. I don't like them might as well bolt it together with a 2x4 Ken
Old 01-11-2017, 09:41 PM
samiam4's Avatar
Thanks Ken,
I see the measurements on line and it will be easy to make a pair out of some rubber sheet stock.
Old 01-11-2017, 10:20 PM
Daytrepper's Avatar
LMC Truck makes a rubber set...around $80, includes cab bushings, and rad support bushings.
mknittle (01-12-2017)
Old 01-12-2017, 08:07 AM
Jim5870's Avatar
maybe trim a little of the coil on the right side to compensate
Old 01-12-2017, 06:03 PM
i looked at the LMC site I see the poly mounts listed but not Rubber Ken
Old 01-12-2017, 07:28 PM
Daytrepper's Avatar
My mistake, just looked at my LMC catalog, they are poly. They do have a bit of give to them. Not totally rock hard.
spdnby
08-15-2008 10:06 PM
Supernova
11-29-2005 11:43 AM
banzaitoyota
10-09-2003 11:15 PM
banzaitoyota
09-29-2003 02:34 PM
Quick Reply: Tell me a bout suspension droop? D250
