Replacing valve seals
Old 11-13-2011, 04:21 PM
Exekiel69's Avatar
I will be sending My injectors to have them rebuilt and thought while I wait I could try and do the valve seals since the oil they are leaking through the exhaust is stating to annoy Me.
Is it better if I turn the engine until the piston I'm working on is at the highest then compress the valve spring and remove the keeper and then replace the seal or is there a better way?
Thanks.
Old 11-13-2011, 04:44 PM
jimbo486's Avatar
I believe that's just about the easiest, safest and only way to do it. It might take some time having to rotate the engine after every other set of valves but you'll only have to turn it 3 times.
Old 11-13-2011, 06:07 PM
Exekiel69's Avatar
I have some trouble finding TDC but I thought once the injectors are out I could put a straw down the injector hole and see how far up it goes then when it starts to return and the valve springs are fully decompressed it should be right on the spot I need it do start taking the valves apart.
I can turn the engine by turning the alternator so that wont the too hard. I was thinking once the valves are decompressed I could remove the lock clip on each rocker arm (I&E) then get full access to the valves.
Btw, since You said I will only have to turn it 3 times on what sequence do they reach TDC. This will save Me using 6 straws .
Old 11-13-2011, 07:43 PM
jimbo486's Avatar
Have you tried using the timing pin underneath the injection pump? It locks into the pump gear which ensures TDC #1.
Being an inline motor, each cylinder has a companion. #1 and #6, #2 and #5, #3 and #4 rise and fall together. When one cylinder is firing, the other is on split overlap or TDC of the exhaust/intake stroke
Find TDC for #1 and you can replace the seals there and at #6, same for when you find TDC for #2, replace seals there and at #5, then find TDC for #3 replace those seals as well as seals at #4.
Old 11-13-2011, 07:47 PM
Exekiel69's Avatar
Thank You, I needed that information.
Old 11-14-2011, 06:23 PM
Jim5870's Avatar
Will he need something to hold the valve up?
Can the valve drop down out of reach?
Old 11-14-2011, 06:38 PM
1st Generation Admin
BC847's Avatar
The point of rotating the engine is to ensure the piston of a given cylinder is at TDC so that when he does remove the valve-spring keepers, the valve can not fall into the cylinder.
And if I'm not mistaken, if the piston were at BDC, the valve could possibly drop below the point you could pull it back up by hand using any exposed valve-stem. Then there's the question of could you be lucky enough to be able to rotate the engine and have the piston push the valve back up so you could grab its stem, without it potentially causing a problem. How lucky do you feel?
Folks, consider this: Once you get #1 cylinder at TDC as verified by the timing pin, make a scratch on the crankshaft damper right next to where the serpentine belt goes by the damper. Just line the mark up with the flat edge of the belt. Eye-ball it.
That way, it's SO much easier to get things back to TDC without fiddling with the timing pin.
Old 11-14-2011, 07:23 PM
Rick 12v CTD's Avatar
And once you've found TDC for #1. just rotate the crank 1/3 of a revolution and then you got your next 2 cylinders at their tdc. Or just look for crossover, it's super easy.
Old 11-14-2011, 10:54 PM
mhuppertz's Avatar
I'm actually surprised you are getting oil into the exhaust through the valve guides. It's a problem on gasser intakes because they are under vacuum, but our engines are under pressure most of the time intake and exhaust. If the guides are shot I could see some oil wheeping down the valve stems causing a puff on startup, but my POD's do that anyway. I could actually see wasted guides causing enough blowby up the stem to blow the seals off their seats. How do you know they are leaking oil on you?
Old 11-15-2011, 07:18 PM
Exekiel69's Avatar
I don't know that , but I did see a thin line of oil on the down pipe (a few months ago) so I pulled the turbo thinking it was leaking and found the oil line coming from the exhaust manifold ( I actually started a thread back then asking about this) toward the front. I do not have oil consumption so I didn't think it was too extreme, and since I removed the injectors to have them rebuilt I tried to tackle it today after work but I chickened out, I don't think I'm finding TDC so I'm afraid to drop a valve and loose it. Still have the new valve seals in the box.
btw when I pulled the injectors #2 and #6 were very wet while the other injectors were dry with some carbon build up.
Old 11-15-2011, 07:37 PM
mhuppertz's Avatar
You probably just have leaky injectors causing your oil slobber!
Old 05-22-2018, 09:01 AM
terrill cotton's Avatar
Truck smokes too.
I was wondering the same thing. My truck is an 06, it smokes more when it's warm but let as it cools. I don't know if it's an injector or valve seal. Smells like oil to me but every once in awhile I hesitate to start on the first spin. Still has power and runs fine. What you guys think?
Old 05-22-2018, 09:07 AM
mhuppertz's Avatar
Probably not valve stem seals. They leak down on cold start and puff blue. Usually isn't much of an issue on Diesels because there is no throttle body to create vacuum that sucks oil past the intake valve seal.
lgp9999
02-13-2010 03:12 PM
case310350
06-06-2009 10:45 PM
Doj Dewd
10-09-2008 08:24 PM
ryanihf250
02-10-2008 10:53 AM
cLAYH
11-05-2006 09:41 PM
Quick Reply: Replacing valve seals
