Fss?
Old 05-20-2018, 01:26 PM
nonrev's Avatar
Fss?
Ok so I got fuel yesterday went to start the truck, it would spin over as normal but no start, so checked the wires on the fss, both on and hooked tight so pumped the primer a few times it was on the lobe so I had the wife bump the key and presto it fired right up.
Now this morning I change the oil and when I went to start it and again no go so I primed it about 20 pumps still no go, banged on the fss it fired right up. I guess my question is has anyone had the fss stick in the closed position?
Old 05-20-2018, 02:25 PM
nonrev's Avatar
Well I removed the fss it appears normal seems to work like it should, is there something in IP that could be going bad?
Old 05-20-2018, 03:11 PM
mknittle's Avatar
Mine did that when the fuel heater O-ring went bad.
nonrev (05-21-2018)
Old 05-21-2018, 11:02 AM
maybe368's Avatar
Yup, I was going to say suction side air leak...Mark
mknittle (05-21-2018)
Old 05-21-2018, 05:47 PM
nonrev's Avatar
Well it has been starting every day so far, one thing I did check was for leaks in the system by putting 8 lbs of air in the tank, would that make the fuel heater leak if the oring was bad
Old 05-22-2018, 10:16 AM
maybe368's Avatar
It should, but it seems that you have a very small leak. See what happens when it sits a day or 2. Maybe it has fixed itself, Ya' gotta' love it...Mark
Old 05-22-2018, 03:11 PM
nonrev's Avatar
Ha Ha this poor old girl never gets to rest for more than about 12 hours 👀
Onemoparnut
01-03-2021 11:51 AM
The_Head
11-16-2010 03:00 PM
NE frmhnd
08-09-2010 06:44 AM
schamran
02-01-2010 09:36 PM
Quick Reply: Fss?
