Rear Main Seal Install
Old 08-11-2014, 04:28 PM
  #46
freight train's Avatar
You guys were correct. I ordered one today from Cummins of Baltimore. I hope to have tomorrow. Thank you
Old 08-11-2014, 04:33 PM
  #47
james1's Avatar
Question
Originally Posted by james1
Apololgize in advance for being dense -- please confirm the following is correct? TIA.
1. After removing old seal and cleaning area thoroughly, first step is to separate the white plastic installation sleeve from the seal and push the white installation sleeve onto the crank hub.
2. Step two is install the new seal onto the crank hub.
3. Step three is to remove the white plastic installation sleeve.
4. Step four is to drive the new seal to proper depth using the round metal seal driver supplied by Cummins.
5. Step five is to remove the metal seal driver.
6. Last step is to replace the flywheel/flexplate.
Again, thanks in advance.
Sorry to be a noodge, but no one ever answered this. Would someone who has replaced his seal be kind enough to confirm the above-listed steps? TIA.
Old 08-11-2014, 08:23 PM
  #48
dieselJon's Avatar
Yep. That's how I did mine. Been 1k miles and no leaking yet.
Old 08-11-2014, 08:47 PM
  #49
Agreed. I have installed three new rear mains and everyone went in without trouble. I used brakeKleen on a rag and my pocket screwdriver to clean thoroughly around the crank surface. The depth tool is perfect. The only issue is once I had a little trouble of the seal popping out one side at a time when I was tapping on the depth tool. Laying on my side and using my entire hand to hold the depth tool flush on the seal. I hit the skin between my index finger and thumb. A blood bubble immediately formed the size of a dime. Hurt like a. Other than that not a drop sense on any of the three I have installed.
Old 08-12-2014, 12:48 AM
  #50
jimbo486's Avatar
Sounds like what I did as well.
Old 08-12-2014, 08:20 AM
  #51
Bob L's Avatar
Me too.
Old 02-22-2015, 10:32 AM
  #52
DOZENVALVE's Avatar
im going to do a rear main soon when I do a clutch, and I am curious if anyone hear about using second gen rear main seals because they are better. I read this somewhere on here.... no sure if it was a line of crap or not but now I can not find it.
Old 02-22-2015, 11:27 AM
  #53
1st Generation Admin
BC847's Avatar
The 1st and 2nd gen seals should be exactly the same.
Old 02-22-2015, 11:42 AM
  #54
DOZENVALVE's Avatar
10-4, I must have misread something or read a line of BS. I figured they should technically be the same.
Old 02-22-2015, 07:08 PM
  #55
mknittle's Avatar
I did mine last week I felt bad about you getting a big blood blister so in solidarity I hit my thumb.
6spd05Dually
05-12-2011 09:44 PM
gozapper
05-01-2010 11:02 AM
jay_d
04-10-2010 09:33 PM
Billut
02-20-2010 05:44 PM
bnold
07-07-2007 06:18 PM
Quick Reply: Rear Main Seal Install
