put an hx35 on my 93 d350 5 speed 2wd and it made it slower
It's not an eBay turbo by any means, but it's not a holset, it's somewhere in between, my gauge hasn't come in yet but it sounds like it's pushing some mean boost, it almost sounds like my fuel to air ratio is so off that I'm not pushing enough fuel to keep up with the turbo, I'm about to install a denny t fuel pin and some 100 hp injectors I have, think this will help?
One other thing, you say you have a boost gauge coming, do you also have an EGT coming?
If not, no way in heck would I change ANYTHING until I had reliable EGT readings.
You can burn that thing down right now.............
I have boost, egt, and Trans temp gages coming, it is an hx35 turbo, I never said it wasn't and I don't know where your getting that from, can't recall the brand because I've been at work all day and I couldn't look at it. But it is an hx35
HX35W 3539911 Diesel Turbo ChargerFor 1994-1995 Dodge Ram Truck with Cummins 6BT 5.9L Diesel EngineReplace Factory Turbo 160 HP Auto Transmission or 175 HP Manual Transmission Fits the Following Applications Modelodge Ram Year:1994-1995 Engine: 160 HP Auto Transmission or 175 HP Manual Transmission Frame Size Turbine Housing Size :HX35W 12CM2 Part # : 3539911 Cummins # : NA 3802839 C.H.R.A.# : 3537815 OEM PN: 3533320 3534333 Item(s) Specification : - Air Inlet: 4" - Compressed Air Outlet: 2.25" V-band - Bearing: Journal Bearing Turbine - Turbine Housing Flange: Standard T3 - Exhaust Outlet: V-Band - 300~500 WHP - Oil Cooled - Wastegate PSI: 19.29 PSI or 1.33 bar High Quality Turbo, Each one is Computer Balanced and Tested.
holset is not the only company that makes hx35, here is the product description--------
Since the '94 and '95 auto OR manual 12Vs DID NOT come with HX35s, I am guessing this is some company PRETENDING to know what is up and selling knock off turbos.
I think we found your problem.
Put your old turbo back on ,install some gauges and then start your with your planned power mods.
