put an hx35 on my 93 d350 5 speed 2wd and it made it slower
Old 12-15-2014, 12:38 AM
gaberichison's Avatar
I recently purchased anew hx35 turbo for my first gen, and after installing it, my truck has lost a lot of power, also gained a couple of seconds on the zero to sixty, I did a waste gate delete too, still no increase in power. It spools up quick then nothing, someone please help and explain to me what's going on
Old 12-15-2014, 01:52 AM
Nughuffer's Avatar
What is a waste gate delete? Sounds like you have boost leaks to hunt down. Does it smoke a lot and have high EGT's too?
Old 12-15-2014, 02:04 AM
All you do is unbolt the wastgate and plug up the hole
Old 12-15-2014, 07:26 AM
Unless it's untaxed, then it's red.
#2isgreen's Avatar
Do yo have a boost gauge?
You say New - new ebay? Or an actual holset? There's some threads on here about 5 blade vs 7, I forget which is a knock off for imports.
Old 12-15-2014, 11:31 AM
It's not an eBay turbo by any means, but it's not a holset, it's somewhere in between, my gauge hasn't come in yet but it sounds like it's pushing some mean boost, it almost sounds like my fuel to air ratio is so off that I'm not pushing enough fuel to keep up with the turbo, I'm about to install a denny t fuel pin and some 100 hp injectors I have, think this will help?
Old 12-15-2014, 01:38 PM
dan123dbl's Avatar
If you didn't change any fuel settings you're not "not pushing enough fuel to keep up with the turbo"
The hx35 has a 12cm exhaust housing opposed to your 18.5 or 21cm that was on the h1c.
It will spool a lot faster down low and might get a little hotter up top. Gauges are a must for knowing what's going on before modding anything.
What do you mean by 100hp injectors? What's the hole count on them, size of the holes and spray angle of the injector?
I've heard a lot of people say the denny t fuel pin is cut too deep and allows the slide pin to come out too far which makes the o ring start to leak fuel.
When you say it sounds like it's pushing some mean boost, can you hear a "wooshing" sound under the hood? Maybe you have a boost leak from not tightening up a clamp all the way.
Old 12-15-2014, 01:47 PM
By mean, boost I mean you can hear it out of the exhaust, I can't here any leaks under the hood, my Guage is on the way so I will know how much boost it's pushing when that comes in, I can't remember the injector specs just know that they spray enough to add anywhere from 75-100 hp, also I have never heard anything negative about the denny ts, my best guess until I get a gauge is that my fuel air ratio is all out of whack, does that sound about right?
Old 12-15-2014, 01:54 PM
dan123dbl's Avatar
Well I'd be interested in hearing about your boost / egts when you get your gauges.
The problem with not knowing the injector specs is that you could be getting a 4 hole injector with a 155* spray angle (meant for non ic trucks) when your truck is IC and needs 145*. Or vise versa.
You should probably hold off on installing them until you can get some sort of baseline readings on your gauges.
Old 12-15-2014, 02:21 PM
Received 2,392 Likes on 1,576 Posts
I would stop throwing performance parts at a truck that is not running great, until you get gauges hooked up.
I install gauges FIRST EVERY TIME, even though I know it is not a "fun" as throwing go fast parts at it.
It is hard to know what your doing, or how to track down problems and you end up…well right where you already are.
Old 12-15-2014, 02:52 PM
bobva's Avatar
Waste gate delete no good = all your doing is blowing a lot of HOT air.
Hot air = no power
Compressed air is hot.
Old 12-15-2014, 03:50 PM
My injectors are meant for an intercooler cummins, my gauge should be here in a week or so
Old 12-15-2014, 03:52 PM
I wasn't too concerned about the hot air since my truck is intercooled, I knew that a wastgate delete was a nono for a non Ic but I figured it wouldn't be a problem for an intercooled cummins
Old 12-15-2014, 04:28 PM
dan123dbl's Avatar
An intercooler won't fix that if the turbos blowing hot air. When you get your gauges i'd set your wastegate to 35psi max
Old 12-15-2014, 04:29 PM
Okay, so would that be why it seems to be so much slower?
Old 12-15-2014, 04:31 PM
dan123dbl's Avatar
Possibly.
It's hard to say because you have no gauge information to go off of.
I'd still check to make sure your boots are clamped down tightly though.
Quick Reply: put an hx35 on my 93 d350 5 speed 2wd and it made it slower
