Piston Lift Pump Install
#61
I was finding outrageous prices from cummins as well..... And at case! But I called Sacramento Truck center and bought a boatload of parts (including 3 metal connector rod upgrades for our rpm gov control)
But if I recall the pump was 178.00 AND they had to order it from the "factory" so it is a new current unit.
Sac truck guys were much friendlier and helpful than my local cummins west guys ever were. I think it is because the cummins west people see the dodge guys coming a mile away, and probably get a lot of small item automotive customers and surely they have their share of horror stories from unhappy custys...
#62
question
So I got all my parts. The fuel line is unavailable at the factory or anywhere in the USA but actually 26 lines will be released next week to the nat'l distributor...
I have a question...... Will the old fuel line bend into place temporarily? Do you really need that new fuel line. ? Or is it not long enough. What about a custom flex hose from a local hose and fitting house.
#63
I was going to make my own line out of the old one but I though it would be easier to buy a new one. wrong.
The old line is a little short to rebend, so I was going to use the ends and custom make a hose.
#64
cool I see that these lines are a hot ticket. let me know how your custom fab comes out. I may take the line down to the hose n fitting house and see if they have couplers to fit the ends to flex hose.
But I also have a question about your truck. If you have an f450 rear frame, why not have the dana 110 under there ;-) like the F550s
#66
Cool mod
Well I am not in too much of a hurry either. I hope to just get the engine stabbed into the w200 by sunday.
But after that I'm out of town till the 2nd week of feb........
#67
#68
Hmmmm, nice and clean, there should be a slick way to fit a 1/8 f npt tap for a fuel pressure gauge in there too. I need to do a LP real soon myself. The gears are turning.
#69
#71
After you fight those rigid hard-lines, crossing threads, skinning knuckles, and dropping bolts, then do the same job with flexible rubber lines in about 1/10 of the time/hassle, the cost of a few JIC fittings begins to look like a bargain.
JIC and AN are basically the same for our intents and purposes.
The fit and design is identicle, just the quality-control is supposed to be tougher for the AN, which means ArmyNavy.
JIC = JointInternationalConference = 37* Flare, as opposed to plain old 45* plumbing flare.
I have almost entirely got my truck plumbed 100% JIC/PushLok from all three fuel-tanks, through an army of valves and filters, including Returns.
Once you have things converted to rubber-hose and JIC ends, diagnosing and maintaining the fuel-system becomes a lot less of a hassle.
By the way, Mr. Eskimo Man (ofc marc), I saw on the weather where you were between -40 and -50 last night; I bet the smoke freezes in the chimney and the dipper will be froze in the water-bucket this morning.
#73
Thanks a lot OFFICER MARC I really appreciate it. This will be on the agenda today.....
#74
Ok Thanks for the idea Marc, I have the new custom fuel line parts in hand. They look awesome and it will work great.
FYI future Piston Pump Buyers: I know the price has been "going up" as some said to over 300 bones but I found mine for 175 from a big rig truck place using cummins PNs. It is a cummins part they ordered from the factory overnight. It came here and looks good but it is "made in china" Isn't this supposed to be a Carter pump.
#75
I also plan on a remot filter setup theat will allow easier changes when I gel up. But that is a whole different story.
