PCM fail
PCM fail
Is their anyone out there that repairs or exchanges 92 - 93 automatic PCMs?
Mine is acting up. No grid heater preheat, only starts working after the engine starts.
Also the the alternator over volts after start up for a few seconds, then the wait to start light blinks on, the voltage goes to normal and the grid heaters start cycling down normally. Why the alternator is over volting is strange, it is on an external regulator.
Call me crazy but it doesn't sound like a pcm to me. I agree with bad ground or some other gremlin
Grounds are good. Thought part of it might be a bad crank sensor, so I replaced it. What a miserable job that was. And to prevent any more over voltage situations I removed the PCM from the auto shutdown circuit. Easy, just snip and ground one wire at the relay. I'll have to wit and see if the grid heater function has returned to normal. If it hasn't, I'll put in my spare PCM.
Here you go: Dodge ECM Repair and Return - SIA Electronics ...Mark
I repaired, replaced, and added grounds shortly after I bought the truck because of electrical gremlins. Also had my harness out a couple times trying to fix bad splices and broken wires. I need to just build a new harness and be done with it.
I put my spare PCM in this weekend and most things are working again. My spare was my original that had a bunch of problems. Some I fixed by re-soldering any cold solder joints I found and replaced a couple bad caps. The alternator and OD circuits don't work, but those are bypassed anyway by an external regulator and the Compushift.
gyman98 (03-26-2017)
Pit Bull
05-23-2003 01:36 PM
sdgunslinger
18
01-09-2003 07:12 AM
