By passing the TPS on a auto for first gen Cummins
My TPS is not working at all and I just replaced it a week ago. Can I by pass it by using a switch to turn on my O/D? Need help!!!
Are you sure the TPS is bad? There's several other items that can keep it from going into OD, including temp sensors, TPS adjustment, PCM, and a multitude of connectors.
If the TPS is bad, There are options to install a direct switch to the OD, a potentiometer to manually select the shift point, a fifty cent pair of resistors to do the same, only not adjustable, and a couple of ways to mount a gasser TPS which costs about 15% as much as the OEM.
If the TPS isn't the problem, only the direct switch will help.
BTW, proper diagnostics, that is determining exactly what is wrong to start with, is the fastest and least expensive path to a repair.
Generally speaking, guessing and throwing parts at it is the slowest and most expensive path.
I know for a fact that's its my TPS. And if I replaced it, it would the three d time that I replaced. I"ve heard of guys putting a switch to by pass it and do away with the push button on the dash. It just seems easier to do it that way, I think. Its just needs to work for a couple more mouths untill I put a Getrag 360 in my truck to completely do away with the automatic.
It would take a combination of dead short to ground or 5V, combined with gross mis-adjustment to fry the TPS quickly. The design is flawed, with DC current through a moving potentiometer wiper, and that is what wipes them out in a year or 2.
Interesting...where can I find the material to build this contraption. So, when this is built I put it into the TPS and put a ground on one side and 5+ volts on the other? To test if it works?
It shoves into the TPS connector just like you see it displayed.
Before you get your knickers in a knot, you should back probe the tps connector when connected and verify 5V, 0V, and center terminal out of range and/or not varying with throttle movement.
If all the above is true, then disconnect the TPS and probe ohms from one end terminal to the center terminal and operate the throttle. It should sweep from about 1000 ohms to 3000 ohms, smoothly. The numbers aren't important, but the smooth sweep is. If that's OK, then there's a fault somewhere else in the circuit.
I probably have one of the resistor twins laying around if you need to borrow it. I've replaced both of mine with these:
https://www.dieseltruckresource.com/...stable-317923/
97CTD
07-29-2007 08:22 AM
Sittenbull2
05-15-2003 04:15 AM
Central Texan
16
01-19-2003 08:24 PM
