OK, Let's renew our AC system
#106
A wise old man(my father) once told me that once you've blown that pop valve, it will pop much easier and more frequently from then on. We had one pop on a tractor this summer and had to replace the compressor because the valve was just wide open after that.
As for a pressure switch. I installed one from a Mack truck in my 03 cummins project. It's a binary switch so it will cut out if it gets too low or too high. I'll have to scrounge for a part # if you're interested. But just google "a/c binary switch"
#108
Mr. Edwin,
I use a 3/8" handle like this to access my serpentine belt, the head is flat so it fits the narrow space behind the shroud.
Like this one.
Ace Hardware Stores | Browse for Hardware, Home Improvement, and Tools.
My current tensioner also has the 1/2" square drive so I have a 1" section of 1/2" OD X 3/8" ID square tube as an insert then I use my 3/8" handle, this works perfect.
A 10" section of 3/4 PVC acts as a sliding handle for additional leverage.
You can also use a section of 3/8" or 1/2" square stock and a long handle open end wrench.
How do you have your fans set up, I have my 2 fans on separate 30-amp relays and circuit breakers both triggered off the compressor, I can also control them manually with a switch.
With R-134a additional airflow is almost mandatory.
I also feel that after a spring loaded relief trips it should be replaced.
Jim
Like this one.
Jim
#109
Is there a reason you prefer this complicated setup to a 1/2" drive breaker bar?
Jim
Jim
#110
Jim
Jim
I would have to drain my radiator to get to the pop-off valve which is on the output manifold of the compressor. I put it on new when I started this job. The last time I was watching and it popped at about 600 psi so I think it is a spring loaded one as it seems to be consistent. I just wish it was in a different place so as not to spray oil on the belt.
I think if I keep the fans running it will be ok. This R134a conversion seems to be experimental anyway.
I noticed that your condenser is a lot bigger than mine. Do you have a PN for it? If I keep having troubles I may opt for a bigger one like yours.
These past few weeks we have been running up to Ridgecrest on the weekends to get a rental house ready for new tenants so haven't had a lot of time to play with it. The A/C ran well on the trip up but just not a cool as I would like. I'll try a bit more refrigerant next week and see if I can get it optimized again.
Edwin
#111
Edwin
bigragu
05-24-2014 04:08 PM
junkyarddog_88
03-19-2009 12:14 PM
ctd4stan
10-11-2008 02:04 AM
