New VE Pump, Timing Off. Advice/Thoughts?
#32
It might be a old thread but the trucks and pumps are older and still relevant to all of us.
Installing a VE pump is dead simple. As long as the injection pump gear doesn't move in relation to the Cam gear you can't really install it wrong. The little bit of adjustment we can do by advancing and retarding isn't enough to make it not run and setting the pump to the middle of the adjustment range is just about perfect.
A interesting question I have is with the pump removed and the timing cover ON can the injection pump gear skip a tooth? They are not straight cut gears so it would have to slide forward to become disengaged to then change it's position.
#33
i had the same question/worry. so i jammed a couple of red shop rags in there hoping it would keep it from sliding forward enough to "disengage".
#34
#35
Most who have assisted me in this problem suggested I retard the timing, while some suggested I bump the timing about 1/4". The folks that suggested to retard the timing feel that during my reinstall of the pump I must have overly advanced it. But how? Pump gear supposedly won't skip a tooth, and my timing marks all lined up. Stumped on this one.
#36
I got an old engine missing the IP. The gears and stamped letters are lined up. I have a good Ip. Nothing is set TDC , nothing is locked, or nothing is timed. Nothing fancy can I turn the shaft on the pump to match the keyway gear on the engine and install? Will it work? Or does it have the possibility of being 180 off?
#37
I had a pump rebuilt a couple years ago. When I removed it the engine WAS Not TDC. When I got the pump back from the shop it was locked. I unlocked it, rotated the shaft to match the gear on the engine, and installed. It Worked. Was I just lucky or will that work everytime? Can it be out 180 ?
#38
No. By matching the keyway you can't get the timing off 180 but it won't be correct timing. You could be advanced or retarded some. The way to set the timing now is complex and requires a dial gauge.
93-12Smoke
09-27-2013 11:53 AM
4969joes
03-28-2010 05:26 PM
dodgemaniac
Competition / Pulls / OffRoad
07-31-2008 10:15 AM
