New Extension housing to tranny mount adapter
Old 11-27-2015, 09:37 PM
mhuppertz's Avatar
When I took out my t-case recently to replace 5th, the square adapter came out in pieces.
I had welded it before, but this time it was toast.
So I went to our local Metal Supermarket (yes, it is a real place) and found some thick walled 3" square tubing and had them cut to 5". Just drilled 4 holes and bolted on.
I got four on them cut. They are at least twice as thick as the original so hoping it lasts for the duration!
Old 11-27-2015, 09:59 PM
Mike L's Avatar
Jeez, looks good and sturdy Mark. Hope that's not your blood splattered on the ground?
Cheers!
Mike
Old 11-27-2015, 10:29 PM
mhuppertz's Avatar
Just my metaphorical blood Mike!
Old 11-28-2015, 04:11 AM
Received 1,332 Likes on 862 Posts
Was that the AA pieces that cracked up on you? I know mine seemed a little on the weak side. Something I will have to watch out for I guess.
Old 11-28-2015, 06:23 AM
Received 2,392 Likes on 1,576 Posts
Yeah that AA boxed spacer I used on my black crew looked cheesy to me.
Maybe I should check my closely for cracks too.
Nice looking upgrade.
You would think for the cash AA charges for their parts, they could give you a decent piece of steel block for that spacer.
Old 11-28-2015, 09:29 AM
mhuppertz's Avatar
Every picture I have seen of other's rigs had the thin walled spacer.
Forgive my ignorance, but what is "AA"?
Old 11-28-2015, 09:37 AM
Advanced Adapters the company that makes the Getrag to NV-4500 swap kit that includes that cheesy, gold plated, thin walled adapter.
Old 11-28-2015, 10:06 AM
They also sell that '92-'93 Z-gated shifter linkage to work with the NV-4500/NP-205 that we had to pull the trans 3 times to modify so it worked like it should.
I also upgraded the bolts they included to bolt the 4x4 shifter linkage into the top shifter cover with longer, stronger bolts.
I was less than impressed with the AA kit.
Old 11-28-2015, 10:20 AM
mhuppertz's Avatar
Been so long since I did the conversion I forgot that part wasn't original! I was cursing Dodge for cheaping out like they did on the steering box bushings...
ShawnQ
03-10-2008 10:41 AM
rjm022
12-29-2007 03:19 PM
emoryemt-i
03-06-2006 09:51 AM
tboling
12-09-2005 05:25 PM
john360
09-25-2003 08:47 AM
Quick Reply: New Extension housing to tranny mount adapter
