New Extension housing to tranny mount adapter
When I took out my t-case recently to replace 5th, the square adapter came out in pieces.
I had welded it before, but this time it was toast.
So I went to our local Metal Supermarket (yes, it is a real place) and found some thick walled 3" square tubing and had them cut to 5". Just drilled 4 holes and bolted on.
I got four on them cut. They are at least twice as thick as the original so hoping it lasts for the duration!
Yeah that AA boxed spacer I used on my black crew looked cheesy to me.
Maybe I should check my closely for cracks too.
Nice looking upgrade.
You would think for the cash AA charges for their parts, they could give you a decent piece of steel block for that spacer.
Advanced Adapters the company that makes the Getrag to NV-4500 swap kit that includes that cheesy, gold plated, thin walled adapter.
They also sell that '92-'93 Z-gated shifter linkage to work with the NV-4500/NP-205 that we had to pull the trans 3 times to modify so it worked like it should.
I also upgraded the bolts they included to bolt the 4x4 shifter linkage into the top shifter cover with longer, stronger bolts.
I was less than impressed with the AA kit.
Been so long since I did the conversion I forgot that part wasn't original! I was cursing Dodge for cheaping out like they did on the steering box bushings...
ShawnQ
03-10-2008 10:41 AM
