To muffle or not to muffle
Old 12-20-2014, 05:55 AM
  #31
KRB
KRB's Avatar
I'm ready to pull the trigger but it doesn't seem to distinguish between standard cab and club. I've not heard back yet from the store. Ya'll with club cabs, did the Diamond Eye Performance Exhaust Systems K4211A fit?
Old 12-20-2014, 07:15 AM
  #32
Hillbilly66's Avatar
It's been over a year since I did mine, but I believe that is the kit I got for my club, it came in a bunch of sections. I used every piece of pipe in the kit, a regular cab would probably have a left over section of pipe. I got mine from TV Diesel, I called them and told them I had a club cab and they sent me the kit.
Old 12-20-2014, 10:35 AM
  #33
Redtruck-VA's Avatar
I installed this exhaust on my 89' RC long bed and had extra pieces left over. We did a little cutting and adjusting to get it to fit exactly like I wanted. You won't have a problem.
Old 12-21-2014, 05:22 AM
  #34
KRB
KRB's Avatar
Thanks guys. I was kinda thinking maybe one kit fit all and regular cabs would just have a piece or two left over. Doesn't seem real cost efficient but I guess the bean counters decided extra pipe is cheaper than stocking multiple packages...
Old 12-21-2014, 09:12 AM
  #35
mknittle's Avatar
There isn't an extra pipe. there is one left long so you can cut it to fit.
Old 12-23-2014, 07:27 AM
  #36
KRB
KRB's Avatar
Got it ordered.
I assume it comes with u-bolts and not band clamps correct? The site just says hardware included.
Old 12-23-2014, 08:17 AM
  #37
Got it ordered.
You would be correct, mine came with u-bolts
Old 12-23-2014, 09:58 AM
  #38
A couple of the brackets have hangers of different sizes to mount up to the factory mounts. I used two of them and then welded a generic bracket on the last section to firmly hold the pipe in place. You won't have any problem.
Old 01-17-2015, 12:22 PM
  #39
KRB
KRB's Avatar
Finally a "warm" day and I'm installing the Diamond Eye.
Question:
Does it mount to the bellhousing at all? I'm not replacing the factory pipe, I had a Pinnacle in before this and fabed a mount to the bell housing but I don't remember if stock had one or not?
It didn't come with instructions or directions so I'm winging it. I have two regular uclamps, 3 uclamps with "J" hooks and a little "L" shaped bracket with 3 holes in it.
Thanks,
Old 01-17-2015, 12:57 PM
  #40
KRB
KRB's Avatar
Duh. Never mind, I found the instructions attached to the little box of hardware that was in the big box. Doesn't look like it attaches to the bellhousing.
Old 01-17-2015, 01:47 PM
  #41
Mine didn't mount to the bell housing.
Old 01-17-2015, 03:39 PM
  #42
Jim Lane's Avatar
Your downpipe is not supported at the bellhousing?
Mine at one time fell off and cracked the flange at the turbo.
Jim
Old 01-17-2015, 03:56 PM
  #43
Jim, no I would need to fabricate a new bracket to have it fit the 4" pipe.
Old 01-17-2015, 04:22 PM
  #44
KRB
KRB's Avatar
I've got it all together and trying to line everything up. No matter what I do I can only get about 1/4" from the transfer case. Is that as good as anybody else has gotten?
Old 01-17-2015, 05:32 PM
  #45
archer2's Avatar
Do the best you can with the clearance, it won't be much. I also could not attach mine to the bell housing.
Quick Reply: To muffle or not to muffle
