Mid 90s Ford seat in a 1st gen
Pretty simple install. I started by unbolting the old seat from the sliders. I then used two lengths of 1.5" angle iron cut to 47.75" each. I had to notch out the ends of each piece of angle iron approximately 2 inches to allow clearance for the slider notches and also had to notch the center of one piece of angle iron to clear the transmission tunnel. I then bolted these lengthways across the cab back onto the original sliders. After that al it consisted of was matching up the Ford seat brackets with the angle iron and drilling holes and bolting the seat on. The slider needs some tweaking to work properly but since I'm the only one who drives the truck I have no need to slide the seat
I'm not sure on the exact year but anything from 1980-1997 should be very similar if not identical on the mounting brackets. This one does have lumbar. I thought I could wire it right into the existing seat belt harness wire and have lumbar but apparently not. I'll have to run me a hot wire from the key to the plug connector. I did shim the back of the seat up on both sides so it sat up straighter and I also shimmed up the front left corner to clear the slider handle. There are multiple ways a person could fab up this seat to fit and function but I just used what I had on hand and it was very simple.
Big Dblue
04-16-2011 09:30 AM
JQmile
09-21-2010 10:23 PM
clndesl
02-15-2009 10:06 PM
straight_six
07-26-2008 01:00 AM
Valv
03-18-2007 03:51 PM
