Low buck TPS fix
Old 04-27-2008, 08:29 PM
Rampage1967's Avatar
Low buck TPS fix
Here's a shot of my home built bracket to use a 1989 3.0 V6 TPS on my cummins. The sensor works great & took very little to mount.
Never mind the wiring, it was done quickly for test purposes.
This sensor is easily available & only about $50.00 to buy from any parts store.
Old 04-28-2008, 12:09 AM
Chrisreyn's Avatar
This sir, is inspired!!
However, this needs more information, such as how you fit the TPS to teh throttle shaft, did you have to drill the pump housing to mount it and such...
Old 04-28-2008, 09:22 AM
I'll have to take it apart for pics, but here is the basic procedure.
Remove the stock setup . . .
use stock bracket as a pattern to make one for replacement TPS . . .
narrow ears on throttle shaft adaptor & adjust to allow bottom to hit throttle shaft .. . .
drill & tap mounting holes in new plate for sensor . . . .
install bracket using stock bolts . . .
install sensor & adaptor using. . .
replace wiring plug with one for gasser .. .
Adjust sensor & enjoy . . . .
Old 04-28-2008, 04:25 PM
You are a genius! Please do take it apart to show how you did it, this will be a popular fix to be sure.
Old 04-28-2008, 10:09 PM
Thank you. . will try & get picks for ya all. ;-)
Old 04-29-2008, 01:30 PM
mabchewy's Avatar
This is great!
Old 04-29-2008, 11:38 PM
DBF
DBF's Avatar
Great idea!!!
How much does the 3.0's TPS cost from the dealer?
Tx, DBF
Old 04-29-2008, 11:51 PM
I really don't know . . i took mine off the spare throttle body in the garage.
BTW .. will post pics once approved.
Old 04-30-2008, 04:05 PM
Originally Posted by DBF
Great idea!!!
Tx, DBF
It's a $30 part aftermarket. Fits just about every EFI Chrysler product from the '80's and '90's.
Old 04-30-2008, 04:18 PM
DBF
DBF's Avatar
While you have it apart for pictures, please put the new bracket into a scanner and scan a picture of it. We'll be able to use it as a template to make our own.
Regards, DBF
Old 04-30-2008, 09:03 PM
daking's Avatar
why dont you go with a pintometer tps, my total cost was, um, hum 3$ and i just did it because i was tired of taking the tps ever thing i had to take the pump or and i would recomend doing it to every auto od, i can cruse 80kms/50 - 55miles at 1250 to 1300rpm with 4:10s
Old 04-30-2008, 10:04 PM
here's the pics ;-)
This is the bottom of the sensor I used.
Her is a view of the lightly modified TPS adjuster . .all i did was narrow it to fit gasser TPS & adjust the bolt.
her is the custom Bracket . . I just used the stock one as a pattern, but made a hole to fit the 3.0 TPS. The mount holes are 5MM x .80.
This is the bracket & adjuster in place without the sensor. Yes i know the hole is not round . . I didn't get it centered on first try so ground it oval.
Same view showing connector
Finished install (other than permanent wiring)
This mod works great . truck goes into OD at 30 - 35 on light throttle . .65 or so wide open (high idle is upped). Just adjust it according to stock setting. i have found it is not a sensetive adjustment.
Old 05-01-2008, 12:08 AM
ouchman's Avatar
That's a cool fix and all, but it sure seems like a lot of work when you can just do my $5 all-adjustable fix with a potentiometer from Radio shack...
Check my sig - lots of guys will stand behind me on this I think.
Either way - THUMBS UP to ANYONE who figures out a cheaper way to fix ANYTHING!
Old 05-01-2008, 08:05 AM
I wanted to keep it working like it did from factory . .but not have to pay $200.00+ for a sensor every time it goes bad.
Old 05-01-2008, 04:26 PM
I like it, thanks very much for sharing it.
Quick Reply: Low buck TPS fix
