Info on using 2stroke oil in diesel fuel
Old 10-01-2016, 06:02 AM
m37
m37's Avatar
2-Stroke Oil In Diesel ? A Technical Study
Old 10-01-2016, 09:51 AM
cougar's Avatar
I don't buy it for a second.
Old 10-01-2016, 01:05 PM
deere country's Avatar
I am not surprised at all.
Old 10-01-2016, 01:09 PM
j.fonder's Avatar
There is a great table on lubricity of fuel additives, 2 stroke oil was indeed near the bottom of the list. Top were the biodiesel products. I always look for shell biodiesel
Old 10-01-2016, 05:33 PM
jerseybud's Avatar
200:1 seems low - wasn't the recommendation like 1 ounce to 1 gallon, which would be 1:128
Also, zinc is good in the oil we use in these things, but not in the fuel is what this article is saying?
Wasn't there a paper in the DTR newsletter a few years back that showed some additives were junk but stanadyne and the pennzoil or walmart tc3w was pretty good from a lubricity standpoint?
Is it fair to compare a common rail to a mechanical like the 89-93 6bt?
Old 10-01-2016, 05:49 PM
j.fonder's Avatar
US standard HFRR is 520. At 200:1, 2 stroke reduces fuel to 474 HFRR.
Engine Manufacturers Association recommends an HFRR of less than 460.
Optilube XDP reduces to HFRR of 317. Costs about $3 per 30 gallon tank. Probably the best stuff on the market aside from running say 2% biodiesel.
Old 10-03-2016, 09:48 AM
j_martin's Avatar
Ever get a tank of "bad" fuel.
I run a 28 year old high performance V6 2 cycle engine on my boat. (Merc XR/4) It runs variable oil injection, which will run about 100:1 at idle, and about 45:1 at WOT. I also put about 1:150 oil in the fuel tank. The difference in normal running is negligible, but it might save me from an engine seize between the time of injection failure and alarm and response to said event should it happen.
The same could be said for a little 2 stroke oil in the truck's fuel tank.
I don't normally add 2SO to my diesel fuel, but I do carry a quart of it along with a spare filter and diesel 911 just in case I get another tank of fuel like the one I bought in Wolf Point, MT.
Old 10-03-2016, 10:44 AM
gyman98's Avatar
Ya don't fill up in wolf point! I live about 60miles from there, best to keep moving!
Old 10-03-2016, 08:33 PM
j_martin's Avatar
I found that out the hard way. Took 2 tanks of fuel and about $30 in parts and additives to get the engine running right again.
Old 10-03-2016, 10:25 PM
MrFusion's Avatar
I remember reading a lubricity chart on Bob Is The Oil Guy. If I remember correctly Power Service wasn't rated too well. Not the worst but certainly not the best. I believe that Optilube was one of the top rated additives.
Old 10-05-2016, 01:49 PM
Rickcher's Avatar
That article kept saying "modern diesel injection equipment" or "modern diesel engines". I hardly think our engines are considered "modern equipment". There was a study posted on here years ago that put Supertech two stroke oil towards the top of the list, IIRC. I don't remember what test they used though. I'm sure Optilube is better, it's just not as convenient as Supertech. I may try it though.
1320Fastback (10-05-2016)
Old 10-05-2016, 04:38 PM
Rick 12v CTD's Avatar
What some of you guys are probably referring to is this one
Lubricity Additive Study Results - Diesel Place : Chevrolet and GMC Diesel Truck Forums
The following 2 users liked this post by Rick 12v CTD:
Rickcher (10-05-2016), thrashingcows (10-05-2016)
Old 10-05-2016, 06:37 PM
1320Fastback's Avatar
I had the same thought when reading it. Kept saying to myself this article really doesn't apply to our engines at all.
Old 10-05-2016, 10:35 PM
KATOOM's Avatar
Hmmm..... Who is this "The Fuel Expert", and why should I consider this credible information?
As for running 2-stroke in my truck, well lets see:
1) I know my truck was built 7 years prior to the switch from LSD to ULSD in 2007.
2) The only fuel system component on my truck that was built after 2007 was the VP. But still, a product originally built for LSD fuel.
3) My truck is NOT modern. Actually by definition, a vehicle has to be within 10 years old to be modern. Older than 10 years, you call them classic. 25 years or older and you have an antique.
4) I drive my truck in America and could care less about diesel fuel lubricity in another county. The EPA has our legislation by the short and curlys.
So yeah, dont use 2-stroke in a truck built after 2007 and this article was not meant for a "classic" Cummins.
Old 10-06-2016, 04:23 PM
j.fonder's Avatar
while I think you gentleman are wise and knowledgeable, i think you're looking at this the wrong way. The HFRR rating of these fluids is a wear rating. Wear occurs in any system no matter how old it is. Therefore, these ratings are relevant even for our systems. Unless the age of our vehicles somehow excludes them from wear...
Quick Reply: Info on using 2stroke oil in diesel fuel
