hx35 question
Old 11-04-2008, 01:26 PM
faylorz's Avatar
hx35 question
This has probably been answered before but as far as this turbo goes (hx35) is it pretty much a direct bolt on. Anything else need to be modded on this upgrade? Can I just throw this turbo on my truck and be fairly happy or should I worry about anything else?
Old 11-04-2008, 01:28 PM
Mattster's Avatar
Other than adapting it to a non I/C engine it should be pretty easy. Getting one for my rig soon.
Old 11-04-2008, 03:15 PM
Free89W350's Avatar
It is a direct bolt on, the only thing you will have to get is the oil feed line adapter that goes in the top of the turbo. The non ic turbo's hose thread right into the turbo center section without a adapter and the newer ic trucks and all hx 35 have a larger oil inlet on the turbo center section that is the reason you need a adapter with out it the oil line will not tread into the turbo.
Old 11-04-2008, 04:27 PM
archer39's Avatar
if the hx35 is from a 98.5 or newer (i belive thats the year they switch correct me if i am wrong) you will won't be able to use your downpipe in stock form. They use a different elbow.
Old 11-04-2008, 09:42 PM
gear jammer 91"'s Avatar
You will have to come up with a way to attach the turbo outlet to the crossover tube. I think that would be the trickiest part.
rusty250
03-10-2009 08:24 PM
jcmoyer2004
08-21-2008 07:39 AM
dodgethis91cmns
05-18-2008 01:55 PM
Clucker
0
09-12-2007 01:39 PM
rockjeep73
02-20-2006 11:49 AM
Quick Reply: hx35 question
