How much air pressure to run in the Kelderman setup?
Old 05-23-2016, 01:18 PM
LukeFortney's Avatar
How much air pressure are you guys running in your kelderman bags? I'm running 18lbs in the back. Don't have the fronts installed yet. Hopefully this week.
Old 05-23-2016, 11:23 PM
SchmidtHappens's Avatar
Subbed cuz I just put Kellerman on mine and have no idea what to run
Old 05-24-2016, 09:16 PM
HMX-1's Avatar
I have Firestones, and I'm running between 8 and 12 pounds on the rears. Loaded, I run up to 70.
-Kris
Old 05-24-2016, 09:19 PM
-Kris
Are those the helper bags over top of the axle?
Old 05-25-2016, 10:00 PM
crazy clem's Avatar
I run 20 in mine rides better than my 2016 Jeep
Old 05-26-2016, 08:11 AM
Nice! Wrangler I'm guessing?
Any idea what shock I should order for the rear. I have 3" lift springs plus the kelderman.
This Rancho 9000 says 0-4" lift height:
http://www.amazon.com/Rancho-RS999005-RS9000XL-Series-Shock/dp/B0018YEN6Y/ref=sr_1_8?s=automotive&ie=UTF8&qid=1464213505&vehicle=1992-40-2766-20-31-32--8--217-3-2---1-0&sr=1-8&ymm=1992%3Adodge%3Aw250 http://www.amazon.com/Rancho-RS999005-RS9000XL-Series-Shock/dp/B0018YEN6Y/ref=sr_1_8?s=automotive&ie=UTF8&qid=1464213505&vehicle=1992-40-2766-20-31-32--8--217-3-2---1-0&sr=1-8&ymm=1992%3Adodge%3Aw250
Old 05-31-2016, 12:12 PM
james1's Avatar
Smile
I run a constant 30psi in the front Keldermans; I recheck the pressure about every six months.
In my rear Keldermans I have never measured the pressure -- I simply add air until the bed is level. When you get a heavy load in the bed you are definitely going to have to add air (and subsequently remove air when the bed is empty).
DodgeChallenger
02-19-2015 10:17 PM
underwoodtransp
01-12-2006 10:58 PM
jeff kelderman
03-25-2003 11:04 AM
Luke S
03-24-2003 06:59 AM
Quick Reply: How much air pressure to run in the Kelderman setup?
