How Fast Am I Going?
Old 04-07-2012, 10:10 PM
1972RedNeck's Avatar
On my recently acquired 1993 Cummins, the speedometer doesn't work. The sending unit at the t-case is hooked up. I hooked a slow drill up to the sending unit. Nothing. Where should I start checking?
Old 04-07-2012, 10:14 PM
Lunds Ram's Avatar
The plastic gears behind the speedo and in the transfer case could be bad, mine was compleatly stripped, and possibly check the pcm, it might be going bad
Old 04-07-2012, 10:23 PM
What is the pcm? When I hook a drill to the sending unit (acts like gears in t-case) nothing happens.
Old 04-07-2012, 10:28 PM
Lunds Ram's Avatar
The pcm, I don't denver what it stands for, is kinda like a brain, its in the left front fender by the battery and horns check the sticky on how to test it, and if it checks out then its probably the gears behind the speedo, sticky also has info on repairing and sourcing the gears
Old 04-07-2012, 10:41 PM
Please excuse my newbieness.
What's a sticky?
Old 04-07-2012, 10:47 PM
Lunds Ram's Avatar
https://www.dieseltruckresource.com/...t-t102027.html this is the sticky it has alot of information on how to
Old 04-07-2012, 11:08 PM
DevilzTower's Avatar
PCM = Powertrain Control Module
Located under the driver side fender, behind the battery.
Controls, cruise, speedo, plus many more.
Jim Lane
12-07-2015 09:16 PM
EdmontonCanada
37
12-09-2009 03:18 AM
trik396
03-14-2007 07:57 AM
money_d
06-18-2005 12:08 PM
Cummins600
08-25-2004 04:05 PM
Quick Reply: How Fast Am I Going?
